Old 09-25-2012, 11:29 AM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Can I see your heater core and box delete firewall??
Really thinking of sheet canning the God aweful heater core and box from my engine compartment when I pull the motor and front end off my truck this winter. I have about 1/4" of clearance from my valve cover to that box. The heater hasn't been working for 5 years now. I have a bunch of aluminum sheets and was thinking of making a nice cover but can't remember how big the opening was. Thanks guys!
PS: I'm thinking of just leaving the box inside the cab as is. I'm guessing that just doesn't look right when removed, but if you can prove me wrong, I'd love to see pics of what you did on the inside too!
prostreetC-10 is offline   Reply With Quote
Old 09-25-2012, 01:18 PM   #2
gotchamel
Re: Can I see your heater core and box delete firewall??
Used some aluminium plate then filled and faired.Cardboard template worked fine.I did not weld{dont have 1 or the knowhow}but I used duraglass to fill and fair.
gotchamel is offline   Reply With Quote
Old 09-25-2012, 01:27 PM   #3
hayhauler71
hayhauler71's Avatar
stainless steel
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 09-25-2012, 02:01 PM   #4
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I'm sure you will get a quicker response, as I just pulled all the cab components on my son's cab. I will measure out a template tonight. I am hoping to install a Mojave heater with a plenum and re-use the stock defrost and a/c vents for heat. I am curious as well how it will look without that big black box hanging below the dash.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-25-2012, 03:49 PM   #5
Fitz
Before and after pics. Vintage air blower, evap & heater under the dash on passenger side:
Fitz is offline   Reply With Quote
Old 09-25-2012, 08:24 PM   #6
ItsRandy
ItsRandy's Avatar
I used filler panels. Here's a few pics. Hey...where's Ricky Bobby?
ItsRandy is offline   Reply With Quote
Old 09-25-2012, 09:00 PM   #7
prostreetC-10
My Carbon Footprint
I mix it up from time to time. Nice work Randy!!
Old 09-25-2012, 11:45 PM   #8
YBNORML
YBNORML's Avatar
Here's a few shots of mine, I bought the filler panels from Infanti Rides.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-26-2012, 09:41 AM   #9
prostreetC-10
My Carbon Footprint
Hey Randy.....what in the heck are those ratchet straps hooked to?
Old 09-27-2012, 12:28 AM   #10
ItsRandy
ItsRandy's Avatar
Door hinge bolt holes with eye bolts and one strap on the bottom of the back of the cab...worked great.
Old 09-27-2012, 01:04 AM   #11
MisterE72
Keep Your Nose Clean
Heres mine. i deleted the heater core, added a piece, and covered the gutter.
MisterE72 is offline   Reply With Quote
