Old 11-01-2012, 06:39 PM   #1
JGross
Help Identifying 4l60e Trans
I've searched both the web and this site and I can't seam to decode the identification code for a 4l60e trans I picked up at a junkyard. There is a paper tag on the drivers side rear that has
04CHD on the top of the tag with
04CHD708155259 below
Thanks for any help you can provide.
JGross is offline   Reply With Quote
Old 11-01-2012, 07:28 PM   #2
clinebarger
Re: Help Identifying 4l60e Trans
Im familiar with 4CHD....Which stand for 04, C1500, 4L60E.
The "0" in the front is odd, Maybe a rebuild number???
Got a picture of the tag??
More info.....
clinebarger is offline   Reply With Quote
Old 11-01-2012, 07:31 PM   #3
clinebarger
Sticker ID thats usually on the top of the case....
1 - 4 = 2004
2 - Model
3 - Hydra-Matic 4L60-E
4 - Transmission Asm. as Shipped Number
5 - 4 = Model Year
6 - Julian Date or Day of the Year
7 - Letter After Julian Date Identifies the Plant Shift Build
8 - Bar Code
9 - Serial Number
10 - Broadcast Code
11 - Transmission ID
12 - Build Location Y = Toledo, OH, R = Romulus, MI, 4 = Ramos Arizpe, Mexico
Old 11-01-2012, 07:49 PM   #4
JGross
The tag is hidden behind a bracket. I'm going to put this behind a 5.3 Vortec is there anyway to tell if this transmission came out of a V8 or a V6
Old 11-01-2012, 07:59 PM   #5
clinebarger
Never seen GM put a sticker there on a 4L60E. Rebuilt a couple hundred of them.
Check here.....& report back....
Old 11-01-2012, 08:10 PM   #6
JGross
It's stamped 6CHD037
Old 11-01-2012, 08:44 PM   #7
clinebarger
06 C1500, 4L60E. Or at least the case is.
Are you going tear it down & check it out?
Old 11-02-2012, 07:56 AM   #8
JGross
I don't plan on having it rebuilt, I'm going to change the filter and cross my fingers that it's good. Thanks for your help
Old 08-28-2018, 11:15 PM   #9
scouthusler
My 4L60E is stamped 7KCD121B. KC is the engine code, but for which engine?
What does 121B tell me?
I know the year is 1997. It’s a 1-piece bell housing/transmission. The KC may be KG, some wear in the pan rail.
scouthusler is offline   Reply With Quote
