Old 11-22-2012, 04:37 PM   #1
legendman
legendman's Avatar
Rear gear ratio
Pulled my rear cover off and counted the teeth on ring and pinion
16 on the pinion and 41 on the ring gear, which means its got 2:56 gear ratio.
Originally it had a 305 with a th350 trans.
And I swapped in a 700r4 but I need to figure out which speedo gears to get.
Seems odd that it would have a 2:56 ratio.
Anybody else have a th350 and know what their rear gear ration is?
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 11-22-2012, 05:00 PM   #2
cory d
cory d's Avatar
Re: Rear gear ratio
i dont recall trucks having 2.56? i thought 2.73 was the highest the trcks went. i have 2.73's useless on anything but the freeway
cory d is offline   Reply With Quote
Old 11-22-2012, 05:13 PM   #3
legendman
legendman's Avatar
Re: Rear gear ratio
Yea 2:56 seems kinda odd to me
Got all the numbers off the ring gear:
GM 1235401 16 41 11 83
Last batch "11 83" I think means built 11/83 which would be right in a 84 truck.
Old 11-22-2012, 07:55 PM   #4
C-10 simplex
Re: Rear gear ratio
Yes, i have 2.56 with a TH-350C.
Stiff as hell. This kind of setup of good for if you use the truck for light hauling---lumber, appliances, weekend projects etc.
It is not so good for other things such as towing.
P.S. my GVWR is only 4900 and i guess yours is too.
C-10 simplex is offline   Reply With Quote
Old 11-22-2012, 10:57 PM   #5
legendman
legendman's Avatar
Re: Rear gear ratio
^^^ Good to hear, so I guess I am identifying it correctly then.
I am fine with the ratio, I am dropping a 6.2 diesel in it and see what I can get for mileage with it. Not gonna be in a big hurry to get anywhere and more of a show truck than a work truck.
Old 11-23-2012, 05:19 PM   #6
maxxxy
maxxxy's Avatar
Re: Rear gear ratio
I was just now taking apart y rear end to clean up and paint and decided to check what ratio I have. It's 16 41 2 81. So I have a 2.56 as well.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 11-23-2012, 06:46 PM   #7
Firebirdjones
Re: Rear gear ratio
2.56 is actually a very common gear found in the 8.5's in both cars and trucks.
Firebirdjones is offline   Reply With Quote
Old 11-23-2012, 07:10 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
Re: Rear gear ratio
Are there two dots between the 41 and the 11. On my rear end there was which meant the ratio was 3.73, 41 divided by 11.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-23-2012, 08:04 PM   #9
maxxxy
maxxxy's Avatar
Re: Rear gear ratio
Is a 2.56 rear end useless? I've never heard of people wanting that high of a ratio...
Max
Max's bagged 81
Old 11-23-2012, 08:17 PM   #10
clinebarger
Re: Rear gear ratio
Yeah, And only 2:41's & 2:56's fit that carrier, So if you want lower gears.....You need a carrier also.
clinebarger is offline   Reply With Quote
Old 11-23-2012, 08:20 PM   #11
maxxxy
maxxxy's Avatar
Re: Rear gear ratio
Is the 2.56 at least good for gas mileage? I don't plan to do any towing or anything? Will keeping it affect my acceleration or anything?
Max
Max's bagged 81
Old 11-23-2012, 08:56 PM   #12
C-10 simplex
Re: Rear gear ratio
i guess if you don't live in hilly/mountainous areas it might be ok. In my opinion a fullsize truck with such a high gear is good for moving large but not necessarily heavy things----washing machines etc. The thing that baffles me is my truck has the heavy duty springs, yet has the 2.56 rear---it can support the weight, but has problems moving it------doesn't make sense to me?
As far mileage, probably good with a th-350 or other 3 sp trans. i think i tach around 1800 at 55 mph.
P.S. It affects acceleration big time. Switching to say 4.56 will make a world of difference.
Old 11-23-2012, 09:13 PM   #13
clinebarger
Re: Rear gear ratio
If you had 26" tall tire's maybe. & will still be a dog off the line.
With 28" to 30" diameter tires & 3 spd auto......A 3:08 gear will return the best mileage in my opinion. 3:42's will give better acceleration with a small increase in fuel consumpsion at highway speeds.
Old 11-23-2012, 10:39 PM   #14
legendman
legendman's Avatar
Re: Rear gear ratio
I am swapping in a 6.2, so these gears with an ole slug 6.2 and a 700r4 it will take a week to get up to speed but I will be able to pass a few gas pumps though
Old 11-24-2012, 09:50 AM   #15
Rich84
Rich84's Avatar
Re: Rear gear ratio
My truck had the 2:56 rear.. When I went with the 700 tranny, it was practically asleep on the highway with a 30" tire...found a nice posi carrier and 3:73 gears at the boneyard really woke up my TPI..
Rich84 is offline   Reply With Quote
