Trans codes 0740 & 0785 help
I realized this is the better topic for this question...
I recently finished a swap install. All is well except these two codes that keep popping up. 0740 & 0785. I've checked the wiring and no shorts. Tested the pins for the 2-3 shift solenoid (T, E, and S). All good resistance values. Have the VSS plugged in, brake switch is hooked up (normally closed) circuit. PCM was reprogrammed by Brendan @ LT1swap.com Process of elimination... Just confused as to where to go next. Any ideas (logical ideas)?
Graphic Design / Photography 3D Automotive Renderings jonnyNITRO.com |
Re: Trans codes 0740 & 0785 help
I responded to your other thread,
Just a thought....But if you are running a 4L80E harness with a 4L60E trans & ECM.....Those codes will set because the 4L80E does not have a 3-2 downshift solenoid or a TCC solenoid, Check the harness for pins "T" & "U" at the trans plug. |
Oh, I see what you're saying. Maybe the pins in the trans plug are located in different positions. I'll check that too.
You did check for Ignition power on pin "E"? Should set more codes than that, But Tuners like to turn off alot of stuff the really dont need to.
I did.
I am going to get some time today to crawl under there and check the wire orientation as well as follow the wires back to the PCM to make sure they are all in the right place.
Okay, I mapped the wiring from the trans plug to the PCM/power source and this is what I have.
conn. A - Lt. Green goes to #48 PCM (green) conn. B - Yellow/Blk goes to #47 PCM (green) conn. C - Red/Blk goes to #6 PCM (green) conn. D - Lt. Blue/Wt goes to #8 PCM (green) conn. E - Pink goes to keyed 12V power source conn. L - Yellow/Blk goes to #51 PCM (green) conn. M - Gray goes to #53 PCM (blue) conn. N - Pink goes to #63 PCM (green) conn. P - Red goes to #18 PCM (blue) conn. R - Dk. Blue goes to #17 PCM (blue) conn. S - Brown goes to #2 PCM (green) no wires in "T" or "U" pins.
#7 | |
4L60E
conn. A - Lt. Green goes to #48 PCM (green) conn. B - Yellow/Blk goes to #47 PCM (green) conn. C - Red/Blk goes to #6 PCM (green) conn. D - Lt. Blue/Wt goes to #8 PCM (green) conn. E - Pink goes to keyed 12V power source conn. L - Yellow/Blk goes to #51 PCM (green) conn. M - Gray goes to #53 PCM (blue) conn. N - Pink goes to #63 PCM (green) conn. P - Red goes to #18 PCM (blue) conn. R - Dk. Blue goes to #17 PCM (blue) conn. S - White goes to #79 PCM (blue)*** conn. T - Tan/black goes to #42 PCM (green)*** conn. U - Brown goes to #2 PCM (green)*** Take the pin out of Pin "S" & install it in Pin "U" Run a New wire from pin "T" to #42 PCM (green) Run a New wire from pin "S" to #79 PCM (blue) |
Will do.
I'll get back with the results when it's done. Posted via Mobile Device
Got it done.
No more codes! Thank you so much for your help. Time to tie up the wires and test drive. Posted via Mobile Device
| Bookmarks |
| Tags |
| 0740, 0785, 4l60e, code, trans |
