Old 12-06-2012, 08:42 PM   #1
swells6367
swells6367's Avatar
I want to add 2" of lift
I want to lift my 73 Cheyenne 2" since my previous experience was a jeep Cherokee can I build a spring pack or will blocks do the job my truck does not see much off road mostly street time thank you in advance for your help
swells6367 is offline   Reply With Quote
Old 12-06-2012, 08:59 PM   #2
bohmankid
bohmankid's Avatar
Re: I want to add 2" of lift
2 inch blocks in the back and springs up front will get it done for super cheap.
bohmankid is offline   Reply With Quote
Old 12-06-2012, 09:23 PM   #3
swells6367
swells6367's Avatar
will this change my steering box angle
Old 12-06-2012, 09:47 PM   #4
bohmankid
bohmankid's Avatar
You will not make any adjustments to the steering box. If anything you will just need to get a longer pitman arm. a 2 inch lift will consist of 2 inch blocks in the back, u bolts, hardware, springs for the front, longer pitman arm (if needed).. oh yeah and brake lines and shocks maybe. You could probably get away without lowering the transfer case and not lengthening your driveline with a 2".
Old 12-06-2012, 09:48 PM   #5
bohmankid
bohmankid's Avatar
You can install a lift on these trucks in 8 hours if you have big jack stands, a breaker bar, and a torch.
Old 12-07-2012, 01:31 AM   #6
andrewmp6
If its a 4x4 skyjacker makes a 2.5 inch lift kit.One thing i would add is a steering box brace the 4x4 trucks are known for cracking the frame around the steering box bolts.
Old 12-09-2012, 07:34 PM   #7
chevymadness
I'm in the same position I want a 2.5 lift or 2 inch if its possible I have a half ton 4x2 10 silverado.I would really like to know what springs to get in the front details please.I will be looking online to buy everything ships around here are filled with morons.
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 12-09-2012, 08:14 PM   #8
cory d
cory d's Avatar
cant do too much for for 2 wheel drive. Moog # 6104 will bring the front up a little.
cory d is offline   Reply With Quote
Old 12-10-2012, 04:49 PM   #9
chevymadness
Well that's supprisingly damn useless 2x4s ain't worth a damn anyway I know I can get a 2 inch so someone needs to show me the way as what springs to buy.my front is sagging like a fat lady after 25 years of use when I hit bumps I hit the bump stops god knows how many times my fender has chipped my 31 inch mud tires on 15 inch.
Old 12-10-2012, 05:24 PM   #10
zirk
zirk's Avatar
2wd lifted !
http://67-72chevytrucks.com/vboard/s...d.php?t=442205
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 12-10-2012, 05:34 PM   #11
RandyP
Getting Old; Going Broke
RandyP's Avatar
We put the HD coil springs on the front of my 87 R10, brought the front end up pretty much level with the back end. Moog 6454 I think it was. I know when you order front coil springs from O'Reillys you have the option of the HD springs.
Does not get it up as high as a 4x4 I don't think, but levels it out without bringing the rear down like most do.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 12-10-2012, 06:00 PM   #12
chevymadness
Originally Posted by zirk View Post
Lol I seen plenty of that thread your truck is always the reference on this site to either a 4x2 conversion or lifting a 4x2.
Old 12-10-2012, 06:03 PM   #13
chevymadness
Nice truck so put hd coils everyone says to do that I might have to try that we're did you get your how much.
Old 12-10-2012, 06:38 PM   #14
RandyP
RandyP's Avatar
Has been a few years but it seems they were right about $100 at O'Reillys.
