Old 12-09-2012, 02:49 PM   #1
JCampbell
Another roller cam conversion question...
I've got a '90 454 out of a Suburban that I'm going to be swapping into my dually. I think I'm going to go with a roller cam.
Is there any reason I can't just go to the local pick 'n pull and yank all the roller cam stuff off a Vortec block to retrofit into my '90?
Yes, my '90 block has the roller cam girdle bosses cast into the lifter valley.
JCampbell is offline   Reply With Quote
Old 12-09-2012, 03:13 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Another roller cam conversion question...
You Prob can but I don't think there will be much power gains
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-09-2012, 03:24 PM   #3
JCampbell
Going more for mileage (in a 454, ha!) and longevity. Plus, I don't really want to have to hand-wring over all the zzdp controversy.
Old 12-09-2012, 03:32 PM   #4
thesickc10
The vortec blocks have a plate that bolts to the valley to hold the roller lifters in so i dont know if it would work
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 12-09-2012, 04:12 PM   #5
JCampbell
Old 12-09-2012, 04:41 PM   #6
thesickc10
Missed that part my bad.
Old 12-09-2012, 06:03 PM   #7
INSIDIOUS '86
Haven't had zinc issues with my flat tappet but I'm running royal purp. But bbc do have a nack for eating cams. If anything I say pull the roller stuff but get an aftermarket cam
Old 12-09-2012, 06:32 PM   #8
JCampbell
Yeah. That's what I meant. An aftermarket cam. I just wanted all the factory peripherals to cut down on some of the cost.
Old 12-09-2012, 08:20 PM   #9
INSIDIOUS '86
Yah go ahead get all the stuff the rollers should be good try and find low mile stuff
Old 12-10-2012, 11:34 AM   #10
bnoon
As far as the aftermarket rollers go, the early small block retrofit rollers are EXACTLY the same as the Mark IV big block lifters except for the tie bar lengths. That means the V6 rollers will fit the big block lifter bores and be properly oiled. Now as far as the factory Vortec tie bars and spider are concerned, I have no idea if those are the same to hold those V6 roller lifters in place.
Oh, does your block have the cam thrust retainer bosses to use the (I'm assuming here) stock retainer/etc hold the roller cam in place, or will you be using a retainer button with aftermarket timing cover? I guess this question only makes sense if the big block will need these parts as the small block Chevys do... you know what assuming does. LOL!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
