Old 12-11-2012, 06:42 PM   #1
SuperPat
Door Latch and Lock Problem
Hello, After searching and reading several threads on the door latch and lock problems i still have a different issue. My problem is i have to push on the door to lock it with key. It doesn't matter what position i have the stricker plate in. Just for my own satisfaction a moved the striker as far out as it would go. I still have to push on the door to lock it. This is with my driver and passenger door. I have lubed everything as i read on the past theards. The locks move freely. everything seems to work as it should. I feel my next step is to replace the latch mechanism if i am stuck on fixing this problem. I discovered this issue when i installed VH Coachworks Remote power lock kit. The solenoids will not move the locks unless i push on the door. Any commits would be great.
SuperPat is offline   Reply With Quote
Old 12-11-2012, 07:28 PM   #2
john
member #16
john's Avatar
Re: Door Latch and Lock Problem
Your latch has too much play in it. A new latch will work wonders. I had the same problem with mine.
john is offline   Reply With Quote
Old 12-11-2012, 07:31 PM   #3
ole dollor
ole dollor's Avatar
what john said should fix you up...sounds like they are wore out..
ole dollor is offline   Reply With Quote
Old 12-12-2012, 08:00 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Door Latch and Lock Problem
I just went through this on my 71. I put in a new lock mechanism and re adjusted everything and now I can lock the drivers side door without pushing in on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
