Old 01-11-2013, 08:54 PM   #1
mrhurt73
connector C100 and C153 pin labeled "Ignition 3 Voltage??
does anybody know what this circuit does?
my harness is from a 2001 GMC 5.3 and it has brown wires called "ignition 3 voltage" according to wiring charts, one was in C100 pin n and other C153 pin c.
traced wires out and it ends up on a small black 2 pin connector that i dont remember being hooked up. the other wire off the 2 pin connector seems to hook to a common ground splice.
can i just delete this whole circuit?
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 01-13-2013, 12:28 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: connector C100 and C153 pin labeled "Ignition 3 Voltage??
Front axle actuator circuit for turning 4wd on or something like that, at least per what the little pinout thing on lt1swap says. It doesn't say exactly, maybe a locker or something? All I gather is its for the 4wd, and not used.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
