Old 01-14-2013, 03:42 AM   #1
61 chevy
61 chevy's Avatar
61 chevy rear shocks.
I am having trouble finding rear shocks for my truck. Any advice.
61 chevy is offline   Reply With Quote
Old 01-14-2013, 04:30 AM   #2
Vernski
Re: 61 chevy rear shocks.
Where have you been looking? There are many to chose from Jegs, Summit, Speedway, LMC you can google for any of those, www.ClassicParts.com would be my choice they have a good selection....Vernski
Vernski is offline   Reply With Quote
Old 01-14-2013, 10:47 AM   #3
robber grin
Post Re: 61 chevy rear shocks.
Gabriel did have a shock for these but I think it was discontinued...
On my last 62 Short step I ran these with 2" drop blocks which should not affect shock specs.
Try the late 70's Dodge 2wd (D100)... yes Dodge. The rear shock is a very close match other than the sleeve width which is easily ground down to the stock mount width dimension. Extended / compressed / etc. - near bolt in solution.
Monroe Gasmatic 59045 @ $20 over the counter.
Good luck
bob
robber grin is offline   Reply With Quote
Old 01-14-2013, 03:43 PM   #4
61 chevy
61 chevy's Avatar
thanks, i tried napa but they only listed the front shocks and no rears for 60 to 63. thanks for all the suggestions.
Old 01-14-2013, 04:05 PM   #5
robber grin
Late 70's Dodge 2wd (D100)... rear shock is a very close match other than the sleeve width which is easily ground down to the stock mount width dimension. Extended / compressed / etc. - near bolt in solution
This is a shock they WILL have that WILL work.
Old 01-14-2013, 04:17 PM   #6
thomas_a_reed
thomas_a_reed's Avatar
I used a pair of stock shocks from an 81 on the rear of my 66.. Top bolted in just fine but the bottom sleave had to be shortend to work in the lower mount..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 01-14-2013, 07:15 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Call Napa. Thats where I got mine.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-14-2013, 08:16 PM   #8
LVPhotos
LVPhotos's Avatar
Stock I run Pro Comp 3000s. Brake out a tapemeasure run the eye to eye length. Lots of places will give stock and drop lengths.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-15-2013, 11:39 AM   #9
luvbowties
luvbowties's Avatar
Thumbs up Re: 61 chevy rear shocks.
Monroe Gas-Matics @ 19.99 at Advance Auto Parts.
>> http://shop.advanceautoparts.com/web...&storeId=10151 <<. HTH,
Sam
luvbowties is offline   Reply With Quote
