![]() Join Date: Nov 2012
2/4 drop - what wheels?
Doing a 2/4 drop on a 69 SWB fleetside. Want to know what wheels look best with this drop. What's the best offset, backspacing, and diameter? Pics anyone?
Gene Posted via Mobile Device |
![]() Join Date: Apr 2012
Re: 2/4 drop - what wheels?
What would look best is a 4/6 drop!
2007 VW GTI - SOLD, 2013 Ram 1500 Crew Cab Hemi 4x4 - TRADED (POS), 2006 Silverado 2500 Dirtymax, 2010 Kawasaki ZX-10R (wrecked), 2006 SV650, 2015 ZX-6R ![]() 1968 C10 CST LWB "..... Long beds are like the slightly chubbier sisters to the hot chick, still cute with a lot more to like. hahahaha!" - OrtegaMotor |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
IMHO I think a 3 1/2 front ( 2 1/2 dropped spindle with 1 inch drop spring ) and 5 inch rear drop ( spring with adjustable panhard bar and lowered shocks) with 15 x 8 rallys on 255/70R15's on all 4 corners. My personal preference is a level truck ( which this drop would do ) and the same size tires on all 4 corners.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 03-05-2018 at 06:42 AM. |
So, back to my 2/4 drop...
![]() The reason is that my truck will see some on-track use, so I will need some suspension travel. As well, I will use it to haul loads and tow. So, again, it will need some travel. Having said that, I'd like to figure out what will tuck and fill up the wheel wells nicely. I am starting on the rolling chassis in the next week or two. |
![]() Join Date: Apr 2008
I like 17s that way you can still put a tire with some sidewall on them.
Prestige Worldwide
![]() Join Date: Feb 2001
Air bags.... then you can have all of these drops.
As for the wheels, it really depends on the style and look your after. Do you want to keep it original looking, more modern large diameters or something in the middle? |
air bags are awesome, but if your going to be traveling and towing. stick with a static drop(springs/shocks). theyre more reliable as to if an airbag blows and your stranded on the shoulder where your pretty much screwed.
#9 | |
A great look with a 2/4 drop isa set if 15x8s all around with 235/70/15 front tires and 255/70/15 rear tires.
I am a Referee of life.
68 step put down almost what I did.Except that I did a 2 1/2 front drop so I could use a disc kit.I went with Rallies and 235-70/15 front and 255-70/15 rear.My comp with pics is down or I would post one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#11 | |
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
Guess it depends on the look you are shooting for...
I wanted a real sleeper. A truck that at first glance looked stock. Stock ride height, fairly quiet exhaust but really flashy paint...you know the sort of truck that's all show and no go but would really stick in the twisties and go like stink in the straights. So, 3.5 x 5 in drop, ECE sway bar huge discs with 17x8 in wheels in front, 17x10 's in the rear with a classic industries sway bar in the rear. Exhaust out under the bumper, all emblems shaved and a monster big block up front. 4.10 gears and an overdrive too. Oh Yeah! |
It's not so much the 'look' that I'm chasing. This truck will end up looking like a Foose or Phillips design, simply because of the function. It's going to be low for occasional track day use, not necessarily for looks. It'll have big brakes, Hotchkis suspension, etc. Big block, fuel injected, LSD, etc. Mainly, I am looking for what fits from a tire perspective, so i don't have to monkey around once I get started on this thing. I'm thinking I'll do 18's, simply because of the choices of track tires available to me. Probably 18x8.5 and 18x10 setup.
Any thoughts on offset, backspacing, etc? I like to see a wheel profile that is set back just shy of the fender lip. |
here's mine with 15 x 8"s and 255/70/15
#15 |
Rottenwood Garage Member
275-60-15. Stock 8" steel wheels. 2.5 / 4
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#16 | |
As for wheels, an 18x8 with 4"-4.75" backspace will work, and depending on which rearend you have, an 18x10 with 4.25" bs(early narrower rear) or 4.75"-5" bs(71-72 rearend). For tires, a 255/45/18 front and 295/45/18 rear is a good range to start looking.
#17 | |
#18 |
size
#19 |
@68Stepbed - Thanks for the info on backspacing. That's really what I am looking for. I want a nice side profile on the truck, where the tires barely tuck under the fenders. As for track days, it'll tow my track car and then I'll just take it on track for an occasional run. No autocross. All road course stuff. Mid-Ohio and such.
#20 |
Anyone using later model wheels on a 6-lug? I'm looking at a set of Denali takeoffs.
#21 |
![]() Join Date: Dec 2012
Hi, sweet truck BTW, wanted to ask, what 2.5 drop spindles are you running up front? CPP or ECE, and any rubbing issues. Thanks.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#22 |
I have a 3/4 drop kit on the way. I will be running these torque thrust d's . Rear wheel is 18x10 and 4.5" back space with 305/45/18 tires. Fronts are 18x8 and 4" back space with 245/40/18 tires.they don't rub now and should be fine with the drop as well.
#23 |
Here's another angle. Good luck!!
#24 |
#25 |
![]() ![]() Join Date: Sep 2008
Subscribed
