Old 02-02-2013, 10:38 AM   #1
48gmc
proportioning valve
have a 48 gmc 1/2 ton, master cylinder has 1 outlet, should i put a valve in there, and where to get it...
48gmc is offline   Reply With Quote
Old 02-02-2013, 04:09 PM   #2
LONGHAIR
Re: proportioning valve
You would be much better off converting to a more modern dual reservoir master cylinder. If you still need to cut back on some of the rear brakes so stop lock-up problems, there are adjustable proportioning valves to do that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-02-2013, 05:08 PM   #3
cdowns
cdowns's Avatar
if you have stock brake system in your truck it has functioned pretty darn good for goin on 65years why the heck change it ??? maybe u need to do a real good 4wheel brake job by the book (GMservice manual)to get them to work the way they were designed to work
Old 02-03-2013, 12:52 AM   #4
andrewmp6
A dual bowl is a lot more safer then a single bowl is the main reason to change it.With a single bowl when you lose brakes you lose them all which isn't pretty.
Old 02-04-2013, 08:07 PM   #5
48gmc
Smile Re: proportioning valve
just ordered a dual bowl mc, should get it next week...thanks for info...
