Old 02-05-2013, 02:21 AM   #1
c10 custom
4 speed transmission rebuild kit
hi guys i have a 1947 gmc advance design series truck and its a 4 speed transmission i was wondering where i would get a rebuild kit for the transmission thank you for any help
c10 custom is offline   Reply With Quote
Old 02-05-2013, 02:36 PM   #2
63 & 64 Bowties
and a few others
Re: 4 speed transmission rebuild kit
You might try some of the vendors here:
http://67-72chevytrucks.com/vboard/s...d.php?t=392428
It's from the Pre-47 section, but many of them carry 47-59 parts.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-05-2013, 06:01 PM   #3
_Ogre
_Ogre's Avatar
as many of those transmissions being removed from old trucks on this forum
you might be better off buying one from a board member
they usually don't wear out or break
what's wrong with yours?
shop air compressor timer
Old 02-05-2013, 07:06 PM   #4
OrrieG
OrrieG's Avatar
I'm with Orge, I have never broke or worn out an old granny 4 speed. Around here you can still pick them up for $100 or less (or the newer ones that will fit).
Old 02-05-2013, 08:07 PM   #5
arturo7
arturo7's Avatar
Is this what you're looking for?
http://www.novak-adapt.com/catalog/t...m420_parts.htm
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 02-05-2013, 10:44 PM   #6
c10 custom
well i thought i would go threw the transmission and re do it but if i cant get a rebuild kit then
Old 02-06-2013, 12:55 AM   #7
mr48chev
mr48chev's Avatar
The link that Arturo7 gave has what most people consider the whole rebuild kit for that trans. You don't replace the gears unless they are so worn or chewed up that they don't work good or unless they are broken.
My ongoing truck projects:
Old 02-06-2013, 02:43 PM   #8
_Ogre
_Ogre's Avatar
you can get rebuild parts, but unless the trans you have has a problem i'd use it as is.
if it's leaking out the front or the rear, those seals are easy to replace without tearing into the trans.
the only thing i've replaced on those old heavy duty trans are the rear seal and the speedo drive gear.
i've pulled covers off those trans and have seen chunks broke off the sides of the gears from jamming a gear and they still work fine
Old 02-06-2013, 06:13 PM   #9
1project2many
Look for Transtar on the web. Find the catalog section and look for the SM420. They have major kits minor kits, seals and gaskets, individual synchros, and anything else you might need.
Pretty tough... there's no front seal in that trans.
1project2many is offline   Reply With Quote
Old 02-07-2013, 12:48 AM   #10
sweet70beast
sweet70beast's Avatar
Where is Lethbridge? I have the 4 speed out of my 53 Suburban I will make you a deal on if you're interested.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 02-07-2013, 08:41 AM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
I agree with you taking it down and putting a bearing kit in it. 60yr old trans has to need it. The issue may be finding other parts for the 47 version of it. SM420 was around a long time but in 3 different versions. The popular ones are the 60's versions. Its a simple rebuild I'd go for it and you don't have to worry about it again.
Old 02-08-2013, 03:10 AM   #12
1project2many
Some of the bearings can be obtained from industrial bearing supply houses. It's possible some of the bushings can be obtained that way as well but I've never had to hunt them down outside of a bearing and seal kit.
Old 02-08-2013, 11:24 AM   #13
c10 custom
i think i will just install a bearing kit and go from there maybe change the syncro's while im in there
Old 02-16-2013, 01:53 AM   #14
tttuba
I talked to the guys at the Novak site, Nice people and will help you. I was going to buy that kit to do mine. Unless I am doing something wrong...I think my synchros could use replacing. I try to double clutch even and still grind them. They also have a way of putting in a front seal so when you park downhill you don't leak oil. I haven't used them yet but think they might work. Never thought about seeing if someone here might have one they took out. I too have a 47 gmc and was keeping it pretty much stock.
tttuba is offline   Reply With Quote
Old 02-16-2013, 09:21 AM   #15
DransportGarage
DransportGarage's Avatar
Originally Posted by tttuba View Post
<snip>... I try to double clutch even and still grind them...<snip>
Double clutching...now THERE's a lost art!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 02-16-2013, 01:47 PM   #16
tttuba
And apparently I am not that good at it.
Old 02-17-2013, 10:37 AM   #17
vwjohnny
vwjohnny's Avatar
These folks had a full kit for my 3 speed saginaw That we rebuilt last year. Very helpful and guaranteed it was the correct kit. I think the girl at the desk is named Michelle. She really knows her stuff. Good luck.
Transmission Products Inc
490 W 2nd Street
Tucson, AZ 85705
(520) 884-7134
vwjohnny is offline   Reply With Quote
Old 02-17-2013, 11:38 AM   #18
dwcsr
Hollister Road Co.
dwcsr's Avatar
Double clutching only works if you have a clutch brake built into your input shaft. Otherwise its hit and miss and your better off shifting with no clutch and get the same results
Old 02-17-2013, 06:02 PM   #19
tttuba
I never knew that...good to know...thanks
Old 02-17-2013, 10:48 PM   #20
1project2many
The input shaft can leak oil just driving and the seal conversion is pretty reasonably priced. You shouldn't be grinding gears unless you're trying to downshift into "granny" when coming into a stop. And making that shift happen is a challenge to say the least because there's a significant difference in gear ratio from Low to 1st. If you're not trying to crash through the gears and you're getting grinding, the synchros are probably bad. Hopefully the gears haven't suffered too badly. They're pretty tough, though.
Old 02-17-2013, 11:00 PM   #21
tttuba
Its the downshift that grinds. From fourth to third to second. I never use 1st as it is too low.
Old 06-17-2013, 01:44 AM   #22
Zach B
Zach B's Avatar
Jim Carter (clasictruckparts.com) sells all the seals and bearings.
Zach B is offline   Reply With Quote
Old 06-17-2013, 09:05 AM   #23
mknittle
mknittle's Avatar
Not around hereI'm an ex-log truck driver.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-17-2013, 09:14 AM   #24
DransportGarage
You got me there. I forgot about you professional guys!
Bob
Old 06-17-2013, 09:14 AM   #25
mknittle
mknittle's Avatar
The SM420 is a tough transmission. It was used in up to ton trucks. The only reason I rebuilt the one in my jeep{the only one I run} is I had to replace the main shaft to adapt it to the transfercase.
Mark
My GMC build.
