Old 03-10-2013, 01:05 AM   #1
lukes63chev
TORGUE CONVERTER questions!!!
i am about ready to bolt up my th350 to my 283 i got the flywheel on. i was curious how to manully turn over the motor to bolt the torgue converter bolts, and which way does the torgue converter bolts go or does it no mater. i just rather no then not no.
any adivce in great.
Lukas
lukes63chev is offline   Reply With Quote
Old 03-10-2013, 09:53 AM   #2
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: TORGUE CONVERTER questions!!!
I have a flywheel turner now, but for years just used a big screw driver
http://www.summitracing.com/search/d...-turning-tools
there are cheaper ones out there, try Harbor Freight
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-10-2013, 10:15 AM   #3
LONGHAIR
The proper tool is the best way, but it can be done with-out one. In either case, taking the spark plugs out makes it a lot easier.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-11-2013, 08:59 PM   #4
williamsboys
williamsboys's Avatar
I'm about to do the same thing and its my first time. I was told a good way is to put some longer bolts in the three holes in the harmonic balancer and put a big closed end wrench around one and push or pull up against another bolt. Also agree with longhair take the plugs out.
Williamsboy
williamsboys is offline   Reply With Quote
Old 03-11-2013, 09:18 PM   #5
b454rat
I use my hands....doing it slow so the compression bleeds out...
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 03-11-2013, 09:24 PM   #6
Gumby
Gumby's Avatar
bump the starter...
Gumby is offline   Reply With Quote
Old 03-11-2013, 10:31 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
With the balancer off...
With the balancer on (sorry, small pic)
Then all you need is a 1/2" ratchet to turn it.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-12-2013, 04:14 PM   #8
jfortvalley
flywheel wrench and the convertor bolts go with the nuts to the convertor
jfortvalley is offline   Reply With Quote
283, bagged, c10, chevy, th350
