Ridin' Dirty
Need some advice from you acreage guys or farmer types please!
I'd like to get a new underground fresh water cistern for my acreage. Well water isn't great in my area, so I haul bulk water from town. What type is best? Plastic? Fiberglass? Concrete? I'm thinking of a tank between 1000-1500 gallons capacity. When I moved in there was a well, but I wanted better water so I installed a 350 gal tank in my basement and haul water with a 270 gal tank in my 1 ton truck. I want a proper cistern so I can haul bigger loads, and less trips to the water station. The water is cheep, but the gas to get it adds up.
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
RIP Mr Ron
![]() Join Date: Dec 2005
Re: Fresh water cisterns. Concrete? Plastic? Fiberglass? Pro's/Cons?
I grew up on cistern water. (1952-1965) It was concrete and we used rain water from one side of the house to keep it filled. We only used rain from months with a R in it. (not science but what pop said was law) It didn't kill us so your bought water should be fine.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
Plastic or fiberglass will keep the ground water out, BUT you will want to keep it full. During heavy ground saturating rain, they could float up. I would keep the tank in the basement also pumping from one to the other with a float.
I have a 200 gal tank in my basement that I slow fill from the well then the house pump can run full power. I can drop water into either the well or the tank via piping and quick connects at the back deck. My truck tank is 350 gal. I usually have to haul water 5 months out of the year. A thought full setup is the key to ease of use. A caveman could fill/run mine. Apologies to all the cavemen out there.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Ridin' Dirty
My neighbor has a concrete tank and hates it because it leaks. I'm hoping ground saturation won't be as much as an issue since my house is on the top of a hill and I'd be burying the tank in the side of the hill, within 15 feet of my weeping tile..
The concrete cistern people advertise a pro to a concrete tank is that you don't have to prep the hole as much as if you were installing a plastic/fiberglass tank.
Hole prep is a one time thing. Concrete leakage is FULL time. On a hill? No worries then about float.
A 1 ton truck should be able to handle a 500 gal tank. My 3/4 hardly knows my 350 gal tank (usually haul at 300 gal) is back there. My 1/2 ton knew it though!
Ridin' Dirty
What do you guy know about hole prep for a plastic or fiberglass tank?
As far as the transport tank goes, I just bought a car hauler trailer with two 7000 lb axles, so I'd be putting a nice big tank on the trailer. Much bigger then my truck box can handle.
These guys have water storage tanks:
http://www.zcl.com/products/water-pr...ter-tanks.html And the installation instructions online: http://www.zcl.com/assets/documents/...rage-Tanks.pdf Not saying you have to buy from ZCL, it's just a company that came to mind because I've seen them installed at work before and figured they would have online manuals and such for a quick reference. |
Ridin' Dirty
Thanks for the links
| Bookmarks |
| Tags |
| cistern, concrete, fiberglass, plastic, water |
