Old 04-15-2013, 09:27 PM   #1
rmmurphy
need distributor advce
i have a 68 327/400trans stock with a holley 600.the po put an hei dist. in it. my truck started running rough so I started fishing around under the hood. cap and rotor were trashed, I pulled up on the rotor and the shaft moved up and down about 1/4 od an inch. Thr centrifical advance weights are almost ready to fall off. Anyway heres my question. stock hei or aftermarket dist???
thanks Rob
rmmurphy is offline   Reply With Quote
Old 04-15-2013, 11:59 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: need distributor advce
It kind of depends on how you drive your truck and how you want the engine to look.
I like GM style Hei myself. One reason is if anything happens on a trip parts are readily available.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-16-2013, 12:19 AM   #3
BMERDOC
BMERDOC's Avatar
A stock H.E.I. is about $150. I don't think you'll need much more to get you going again. Make sure you buy a name you recognize and toss it in. If you wanna dial it in better once its running good again update this thread and we'll sort you out.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 04-16-2013, 01:20 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I put a stock HEI in my '72 several years ago. No problems. That's what I'd recommend.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-16-2013, 10:00 PM   #5
rmmurphy
thanks for the input guys. I went with the stock hei
