03-30-2002, 09:34 PM | #1 | |
Bloo
this thing is not meant to run
first it was a pilot shaft bearing, then it was my freind not tightening the clutch before moving the alignment tool, then the free auto tranny turned out to be a 2wd one, then the startor wouldnt work, now its the little ball that screws into the side of the motor!!!!! i sereosly think theres a reason my 4wd wasnt together when i bought it....
all we needs that little ball.... [This message has been edited by Blue_71 (edited March 31, 2002).]
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
03-30-2002, 09:48 PM | #2 |
Blue....
Are you asking for that piece that mounts to a SBC engine...that the z-bar connects to? I have one from a 3-speed....if you can use it, you can have it....just ask for shipping, (which shouldnt be too much) Let me know....I recently pulled a 3-speed out to put an auto in. ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
03-31-2002, 10:53 AM | #3 |
Josh, I believe I brounght you the one ball mount for the 4 speed I sold you. Can't you use that one?? They are like throwaways anyway--.
------------------ 72 Cheyenne, 350, 5spd, LWB, Super trim. 71 GMC JIMMY 4X4 --needs stuff-! |
03-31-2002, 02:48 PM | #4 |
whats wierd is that he cant use the correct 2 bolt bracket with the pivot ball attached to it, the frame pivot bracket on the top of frame rail on his is aligned with one of the two threaded holes of the block for the pivot ball bracket, either the engine is misplaced to far fore or aft or the frame pivot bracket is the wrong one, IE is a 6 cyl one, etc, also if he had 6 cyl frame mount trees then the engine would sit up to high.
some time si odnt bolt the pressure palte assemblt to the flywheel until the tranny is connected ot engine, sometimes that is easier to do, especially on 4x4 vehicles, then the plate will be aligned for sure, hehe i just stick the plate assembly and thne the disc on the input shaft of tranny and then mate engine to tranny, and bolt the 6 plate bolts to the flywheel later on. wish i was down there right now, we oculd get it going good luck ------------------ Randy- Lincoln, IL randy@ccaonline.com -71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it- -'84 Z28 H.O. 305 L69 700R4 GT4 3.73 - 1984 Firebird SE 2.8L T-5 GT4 3.73 -1981 Cutlass Supreme, dunno what im gonna do with it yet... -79 G20 pass van, 350/th350/10bolt *Paint is overrated © RSS Enterprises 2000 |
03-31-2002, 06:06 PM | #5 | |
Bloo
Bubba Green- can you get my a picture of the peice you have?
Huck-nope wouldnt work , ive already told Randy about it and he explained it right. the bracket on frame is lined up perfect with the front hole for the bracket you gave me. i put just a bolt in the motor and treid that just to see if it was lined up like that. freind said it was the same kind they used on race cars that i needed, they bolt straight into the block. im going to try something after while, might work might not but........
03-31-2002, 07:51 PM | #6 |
The 4 x 4 does sit in 6 cyl position with a V8.....thats factory. The smallblock in my longhorn is set in 6 cyl position. When I ran a stick ,I used a screw in pivot ball.....in the foward hole in the block. If you go look at 73 up V8 stick trucks,you should be able to pirate the pivot ball. As far as sittin too high on 6cyl mounts....NO,if any diff, it sits a little low on the nose......69 longhorn.
http://community.webshots.com/user/hotrodhorn |
03-31-2002, 08:13 PM | #7 | |
Bloo
thats sounds like what i need 69 longhorn, just screws in the block in the forward hole. so a 73-87 should have that?
03-31-2002, 08:16 PM | #8 |
It will be screwed into the bell on the 73 up..........69 longhorn.
