Old 05-02-2013, 09:39 AM   #1
72Mountaineer
72Mountaineer's Avatar
Driveshafts
I'm in the process of mocking up things on my '53 3100, I have the Camaro rearend and SBC motor/350TH tranny mounted, next is the driveshaft. I know that whatever I choose probably will have to be altered, but this thing is going to be LONG. I've looked at the local pick-n-pull, nothing seems to be long enough. Any suggestions, besides a custom made one?
72Mountaineer is offline   Reply With Quote
Old 05-02-2013, 10:55 AM   #2
skymangs
skymangs's Avatar
Re: Driveshafts
I used a 2pc S10 4x4 shaft on mine. If you get a 2wd 2pc, you can mix and match front/rear shafts and it'll give you 3-4 inches of length difference. I'm running an S10 4x4 rear diff, with a SBC/TH350 combo as well.
skymangs is offline   Reply With Quote
Old 05-02-2013, 11:11 AM   #3
_Ogre
_Ogre's Avatar
Re: Driveshafts
a 3100 one piece drive shaft is not that long
a 3200 or longer i'd look at 2 piece
i'd go one piece for less complication
quit looking at the fwd drive shafts
shop air compressor timer
Old 05-02-2013, 11:11 AM   #4
Henry50
Henry50's Avatar
Re: Driveshafts
I put a 350 with a short tailshaft th350 in mine I got the distributor as close to the firewall as could.
I'm using a 95 caprice drive shaft that's around 56" long (center to center on u-joints)
It's a perfect fit with about 1 1/2" at the yoke.
Can you put a yoke in the trans and pull it out about 1 1/2" then measure from the center of the u-joint to the center of the u-joint on the rearend?
Henry50 is offline   Reply With Quote
Old 05-19-2013, 07:46 AM   #5
johns truck
Re: Driveshafts
escalade 00 06 54 1/4 cntr to cntr 1310 to gm 3r conversion u joint for my 74 Camaro ten bolt and 1330 to gm 3r joint for th350 with a 7 inch yoke. measured yoke from cntr of u joint to end
johns truck is offline   Reply With Quote
