Lower A-arm Shafts
I replaced the passenger with a Moog unit. I had to get another driver lower a-arm off of a fellow board member. The driver a-arm was new unused stock unit with a shaft installed unused.
Is there any reason at all to swap this one to a Moog unit as well? I figure they are pretty basic components; however, I have the other shaft as I bought it before I knew the entire arm was trashed. Posted via Mobile Device |
Re: Lower A-arm Shafts
No. Use the new one as is.
I like that answer!
Thanks. Posted via Mobile Device |
Hand Crafted C-10
![]() Join Date: Aug 2006
ANY A-arm pivot shafts!
IMHO..use the one you got that's rebuilt but DO run it to a FE shop and have them check the install (a good shop that knows what they're doing). These things are finicky...you'll probably need an alignment anyway so... This was learned from personal experience. ![]() .
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... Last edited by ETsC10; 05-14-2013 at 10:17 PM. Reason: added to post |
