Closed Thread
Old 06-15-2013, 06:35 PM   #7201
mr48chev
mr48chev's Avatar
Re: What did you do to your truck today!
Pulled the wounded 350/350 and am towing it to the carwash to clean it up in preparation for putting the Cad 500 and turbo 400 in it. More power is on the way.
I also ran to the wrecking yard and picked up a pair of the right brackets off a square body to mount the 500 per what others have done.
Now I need to dig in the sheds and find the 425 pan and pickup tube I saved when my wife blew up the 425 I had put in my 82 Deville. She just called my buddy to come get here and tow her home when she did that one.
My ongoing truck projects:
mr48chev is offline
Old 06-15-2013, 07:06 PM   #7202
a.c.1
Got my old man up early. Loaded my bed and cab on the trailer took to work and steam cleaned. Scuffed the underside. Prepped and applied some undercoating. Sitting back with a cool one, watching it dry...Once again, Thank you pops..
a.c.1 is offline
Old 06-15-2013, 07:40 PM   #7203
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
RAT went in the local show.
http://tinyurl.com/k7e6ehz
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 06-17-2013, 02:25 PM   #7204
higXtech
higXtech's Avatar
Replaced my drivers side door latch Sunday. That sucked! I swear to all things holly the passenger side better not fail because i'm not looking forward to doing that job again.
I'd love to put in some fresh door latch screws if any of you know where I can get some.
1968 fleetside - nolimit wide ride front and rear + ridetech
higXtech is offline
Old 06-17-2013, 02:35 PM   #7205
TBONE1964
Cluster King
TBONE1964's Avatar
You should be able to get those screws from LMC.
TBONE1964 is offline
Old 06-17-2013, 03:03 PM   #7206
VWNate1
VWNate1's Avatar
Exclamation Re : Saturday
Hm ;
I tried to post some new pix and it said " board down for mtce. " ~
I also still really would like to learn how to put the text between the pictures , i keep asking no one helps... .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-17-2013, 04:10 PM   #7207
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
I decided to take the stuck on heater , repaired , began by removing the right inner fender :
-Nate
Geezer
VWNate1 is offline
Old 06-17-2013, 04:12 PM   #7208
VWNate1
VWNate1's Avatar
Pic. # 1 is the leading edge of my inner fender .
Pic. # 2 shows the lower edge of my core support .
Pic. # 3 shows the pieces of fender & core support that ripped out .
-Nate
Geezer
VWNate1 is offline
Old 06-17-2013, 04:13 PM   #7209
VWNate1
VWNate1's Avatar
This pic. it the standard $7.00 So. Cal. Pick-A-Part inner fender with not one pin hole of rust .
-Nate
Geezer
VWNate1 is offline
Old 06-17-2013, 04:20 PM   #7210
VWNate1
VWNate1's Avatar
Then I removed the hood & right side hinge (BAD design here Chevrolet Division !) then the heater box to see yet MORE rust holes in the cab :
-Nate
Geezer
VWNate1 is offline
Old 06-17-2013, 04:22 PM   #7211
VWNate1
VWNate1's Avatar
Angry Re: What did you do to your truck today!
Damn ! this crappy board won't allow me to add more pictures...
-Nate
Geezer
VWNate1 is offline
Old 06-17-2013, 04:35 PM   #7212
mcmlxix
Collector of Projects
mcmlxix's Avatar
Looks like I'm moving to Dallas, TX the end of July ... so I sent it to a board member near me that restores cars.... he's going to finish the job I don't have time for anymore... Sad but happy at the same time, I know it will be done now....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 06-17-2013, 08:37 PM   #7213
Roostboy102
Roostboy102's Avatar
Wrapping up the loose ends of my ls swap. CANT FRICKIN WAIT!
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline
Old 06-18-2013, 01:33 AM   #7214
PAWS 72
PAWS 72's Avatar
Glad to see I'm not the only one.
PAWS 72 is offline
Old 06-18-2013, 01:53 AM   #7215
wreckedchevy
wreckedchevy's Avatar
Re: Re : Saturday
Size:  55.7 KB this is a test
Hm ;
spent some time replacing the speedometer cleaned everything up gave it a fresh coat a paint put it all back together and my used speedo was no good.
to answer your question after you attach files preview the post, then just below the preview you can make some changes to it look for where it says attach] you want to type after the last ] ( or see attached photo where I typed in "this is a test". I spend more time fixing relatives computer's then working on my truck, unfortunately it shows.
wreckedchevy is offline
Old 06-18-2013, 01:59 AM   #7216
Sklptrljay
Sklptrljay's Avatar
Started digging through my parts boxes looking for my interior screws. WHY didn't I keep things more organized!
Sklptrljay is offline
Old 06-18-2013, 02:49 AM   #7217
mcmlxix
mcmlxix's Avatar
Zip-Lock bags are your friend....
Rich
mcmlxix is offline
Old 06-18-2013, 05:13 AM   #7218
Gokart Mozart
I keep medicine bottles for just such reasons, too.
Gokart Mozart is offline
Old 06-18-2013, 07:35 AM   #7219
Vacuumed the carpet
special-K is offline
Old 06-18-2013, 08:41 AM   #7220
chopnchaneled
chopnchaneled's Avatar
Washed it, wiped it down. Then it rained again!
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline
Old 06-18-2013, 10:22 AM   #7221
mking
Worked on replacing Rocker panels. Got old one cut out, and found rusted out A-pillar. Waiting on parts to finish.
mking is offline
Old 06-18-2013, 11:11 AM   #7222
VWNate1
VWNate1's Avatar
Post Re : Sat. 6/15/2013
O.K. , I'll try again :
There's NO PLACE to insert text anywhere except at the beginning of each message ! . GRrrrr......
This is the R.F. brakes showing leaky brake cylinder and paper thin shoes worn to the rivets , scored the crap outta the drum too .
-Nate
Geezer
Last edited by VWNate1; 06-18-2013 at 11:12 AM. Reason: Trying to add text between the pictures ~ CAN'T BE DONE !
VWNate1 is offline
Old 06-18-2013, 11:13 AM   #7223
VWNate1
VWNate1's Avatar
Left front showing cracked linings clean through .
-Nate
Geezer
VWNate1 is offline
Old 06-18-2013, 11:13 AM   #7224
VWNate1
VWNate1's Avatar
All done :
-Nate
Geezer
VWNate1 is offline
Old 06-18-2013, 11:18 AM   #7225
VWNate1
VWNate1's Avatar
Post Re : Then :
I removed the right inner fender and discovered the bottom edge of the core support was rusted to junk , pix or of the leading edge of my old inner fender , the bottom of the core support looking up from the fender well , the bits of combined core support , leading edge of the inner fender and bolts , all this broke off in my hands =8-^
Last pic is of the typical So. Cal. Pick-A-Part $7.00 inner fender :
-Nate
Geezer
VWNate1 is offline
Closed Thread
