Old 07-02-2013, 05:28 PM   #851
crakarjax
crakarjax's Avatar
Re: 1972 Chevy p/u NewType Build
Originally Posted by NewType72 View Post
My coworker said his goodbyes round noon and my dad and I finished buttoning up the linkages and grinding the flexplate a bit so she wouldn't destroy my starter.
Considering that the flexplate is a balanced piece, shouldn't you be grinding the starter nose instead?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-02-2013, 06:56 PM   #852
NewType72
NewType72's Avatar
Very true we could have went that route as well. Hold onto your safety guidelines everyone this is a doozy.. We proceeded to have the truck running while my dad laid under it and ground a bevel to the teeth of the flexplate so it should have a semi spec tolerance to it oppose to pulling it off completely to do so. Still needs a hair removed though. But it did function quote well afterwards.
Here at redneck engineering..
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 07-03-2013, 08:12 AM   #853
mcbassin
Still Learning
mcbassin's Avatar
Very clean engine!
Old 07-03-2013, 09:51 AM   #854
knomadd
knomadd's Avatar
Don't let OSHA find out your "bizness" is operating in such conditions. They might shut down redneck engineering.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-03-2013, 10:25 AM   #855
NewType72
NewType72's Avatar
Thank you Mcbassin I kinda love how it looks exactly like the old one just performs soooo much better
Hey I made him wear safety glasses at least I'm glad it didn't go worse and it definitely helped. I gotta look more into it but need a lift to get the best view of it all.
- Dylan
(209)-985-7721
Old 07-03-2013, 10:32 AM   #856
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Hey Dylan, looks great, I've had to trim the nose on a few starters. The manufacturers are using new noses that don't have the clearance for the weights on the flex plate. It was real bad on the 454 in my dually but a little trimming on the nose and it shut right up. A grinder while running now that's scary and I thought I was crazy....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-03-2013, 10:41 AM   #857
NewType72
NewType72's Avatar
Haha not claiming its the right way to do it but I'm glad it worked
The balance plates aren't the issue but the teeth are too straight of a cut so they tick the starter nose as it goes round ill have to get a picture
- Dylan
(209)-985-7721
Old 07-03-2013, 10:45 AM   #858
Ol Blue K20
Just pull the starter there will be marks where it's hitting and trim it. No more crazy stuff!!
Dale
Old 07-03-2013, 11:24 AM   #859
knomadd
knomadd's Avatar
-Duane
Old 07-03-2013, 12:43 PM   #860
NewType72
NewType72's Avatar
Will do
So far she's running very well. Irritated by an exhaust leak on the passenger side and I think I still have some oil dripping but ill need to wash off the back of the block to really find out. She'll get a time up by the weekend with new oil and adjustment
- Dylan
(209)-985-7721
Old 07-08-2013, 03:54 PM   #861
NewType72
NewType72's Avatar
Well new castrol GTX 10-40 in as of Friday night to be rid of the break in fluid with a wix filter to back it all up. That went fairly smooth however I'm Having a major vapor lock issue which stranded me on the freeway at dusk time that really tickled my fancy to be dodging cars in my mirror as I waited for the motor to cool off to get off on the next exit not a fun night at all.
I'm certain the braided steel line I have is compacting and starving the carb for fuel as its too close to the motor so for now does anyone have an idea what part store would carry a heat wrap to help keep the line cool until I can bend up some correct hard line?
Another point was made in that the sock on the filter in my tank could be all clogged up as well causing the starving. So any directions on the best removal of the sender unit to fix that issue? Will also be replacing the rubber line from the tank to the hard line under the cab that should be fun as well.
- Dylan
(209)-985-7721
Old 07-09-2013, 10:44 AM   #862
crakarjax
crakarjax's Avatar
I completely solved my vapor lock issue with a phenolic spacer for my carb, and my engine runs way better with it also. I re-routed my fuel line which probably helped but in the end the carb was just getting too hot. I used this one, as I have a carter (edelbrock) carb: Amazon.com: Mr. Gasket 3404 Phenolic Insulating... Amazon.com: Mr. Gasket 3404 Phenolic Insulating...
Old 07-09-2013, 11:01 AM   #863
NewType72
NewType72's Avatar
Well now that's interesting never heard if an insulated carb spacer before but I'm already running an aluminum spacer with my setup the last four years. I'm gonna guarantee that the fuel line running from the pump up the front of the block between the serpentine setup is getting too much heat. Ill be getting a sleeve this week and then ill be replacing what I was talking of before for the sender unit and hose since I know that needs to be done at this point. Might as well since I'm not driving it right now
- Dylan
(209)-985-7721
Old 07-12-2013, 01:11 PM   #864
NewType72
NewType72's Avatar
Alright vapor lock issue seemingly solved we ran a heat sleeve over the braided steel line comin up from the pump to my filter/carb and drive it around for a good 30 minutes last night runnin in traffic, different rpms, freeway, speed run and no stumble at all she's acting just as she should making commuter cars look slow and worn out instead of the other way around
Bad news I'm gonna have to nix my lovely valve covers they're just too terrible of a casting for even permeated to fix as she still leaks like no tomorrow so guess ill have to run the stock center bolt covers until I find the best replacement for them. Really didn't want the look to go away as I loved my old covers but I can't stand that leak nor the burning smell so off they go I guess
- Dylan
(209)-985-7721
Old 07-12-2013, 02:53 PM   #865
NewType72
NewType72's Avatar
So far the dist. needs to advance a tooth to get a little more timing out of it. Adjust the carb accordingly, adjust the throttle linkage accordingly, get the lockdown to work properly as its not engaging at all, then add that sweet little 6A MSD box to get her running real good and she should be set. Then I can add on my headers in a bit and my upcoming A/C install. Things are looking up boys
Planning to do my thorley headers in a couple weeks because ill need to pull the motor mounts and have them clearances for the pipes. Shouldn't be too bad
- Dylan
(209)-985-7721
Old 07-12-2013, 06:01 PM   #866
knomadd
knomadd's Avatar
Nice! Sounds like you've been busy.
-Duane
Old 07-12-2013, 06:04 PM   #867
NewType72
NewType72's Avatar
Busy dreaming not busy doing lol. I do plan to put a couple hundred miles on my truck this weekend just because I enjoy driving it and i wanna run the motor more than it has but we shall see
- Dylan
(209)-985-7721
Old 07-14-2013, 01:16 PM   #868
NewType72
NewType72's Avatar
Well Vapor lock happened yet again last night so I'm becoming stumped and bummed on this whole situation. so I moved a few lines around again and hopefully it will help currently running two breathers on passenger side and my PVC vale on the other oh guess I should mention I got rid of my leaky as hell perimeter bolt valve covers and now am running the chromie center bolt style ones that came with the new motor this explains the extra hole I have for the second breather.
Tuned the idle down a bit as well so now I can finally hear that cam! She has a gallop to her when warmed up sounds really good never had it before so I'm stoked there. Here's a short video.
http://www.youtube.com/watch?feature...&v=6mUx7r_54jI
- Dylan
(209)-985-7721
Old 07-14-2013, 02:14 PM   #869
shawno72
C/10 junkie
shawno72's Avatar
Sounds real good Dylan.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 07-14-2013, 02:26 PM   #870
NewType72
NewType72's Avatar
Yeah it does cant wait to get the rest of it tuned up correctly to hear it's true power
- Dylan
(209)-985-7721
Old 07-15-2013, 11:29 AM   #871
Ol Blue K20
Sounds great Dylan! You should be proud.
Dale
Old 07-15-2013, 12:45 PM   #872
NewType72
NewType72's Avatar
Very proud just gotta eliminate this vapor lock demons and get the starter snout away from the flywheel and shell be solid as a rock
- Dylan
(209)-985-7721
Old 07-24-2013, 03:52 PM   #873
NewType72
NewType72's Avatar
Looks like I gotta drive my turd to San Fran this weekend nice little 2 hour drive for me. Really hoping my damn vapor lock issue is solved and won't bother me but I have no idea at this point. Guess I'll be taking a crash course
- Dylan
(209)-985-7721
Old 07-24-2013, 04:05 PM   #874
Ol Blue K20
Dylan, you can't call it turd anymore it hurts it's feelings!!!
Dale
Old 07-24-2013, 04:07 PM   #875
NewType72
NewType72's Avatar
Well till it proves to me that it can drive further then 20 miles without crapping out on me she's a turd
- Dylan
(209)-985-7721
1972 chevy c10, cheyenne super, rebuild, restoration, showtruck
