Wheels for a lowered 65?
Hi,
I have a chance at picking up some wheels for my 65 c10. I have a 6 lug 5-1/2 bolt pattern disk brakes in front. I will be doing a 2-1/2" drop spindle drop in front with a 1" drop coil. The rims are 15x8. Will those work okay with that drop? Need help quick as the guy is moving on them fast!!! Please!! Thanks guys! Posted via Mobile Device |
![]() Join Date: Apr 2011
Re: Wheels for a lowered 65?
Pretty sure they will. I'm in process of putting wheels on my 65 and tried a 15x8 and it was fine. I've since changed it to a 15x7 just because I went from 15x10 on the rear ( they were too wide ) to 15x8 with a slightly wider tire so, I wanted a little smaller tire in the front. You could probably sell them if they don't fit. Good luck!
Thanks!!
Does ur ride have the same drop as mine will?
HELP!!!!! Supposed to go look at those wheels today and still not sure if it'll work! Any help would be great!! Just need to know if these 15x8 with 4-1/2" back spacing will work on my 2-1/2" drop spindle and 1" coil dropped front end with disk brakes?? Please!!?!
I have 2 1/2 drop spindles...no coils cut
And u have disks up front right?
Thanks for the response btw. Posted via Mobile Device |
Also what tires are you gonna run on those? White walls? Numbers on tire? I gotta order those next. Was gonna do a thinner white wall but don't know what would look good size wise on those rims. Thanks
Yes, I have front disc brakes. Tires were 255/60 x 15. Using a 295/50 x 15 on the back with 8" wheel.
Thanks. I guess ill go and get those wheels then. $300 bucks for all 4 with beauty rings sounds like I can make them work!! Lol
If it ends up not working, you can probably sell them and make a little money. I think they will work.
Thanks for all the help you guys!! They worked great today, we shall see when I lower it! It looks like it won't be a problem
Tho! Thanks again. I think I did pretty good $300 for the the whole lot of 4 wheels-powder coated- beauty rings- center caps!! Posted via Mobile Device Posted via Mobile Device Last edited by Thefojizzle@me.com; 07-13-2013 at 07:34 PM. |
![]() Join Date: Sep 2009
very nice wheels. I have 15x8 corvette style rally wheels on my truck with I think 4 1/2 bs and they work fine with dropped spindles an 2 in lower springs
Oh glad!!
#15 |
#16 |
Thos elook great, im int he market for some too! Where is the cheapest place to order?
#17 |
The wheel smith was really great for new ones but from help with everyone here I was able to get cheap ones thru craigslist
#18 |
Do u have disk brakes? What lug number and bolt pattern?
#19 |
nice score man, that's a really good deal and you should be happy running them
#20 |
check out summit, they have free shipping and good prices
#21 |
Thanks turkey!
#22 |
Okay guys, another question.
I do like the center caps that came with the truck, however, my idea for te wheels was to have a push thru bullet center cap. Well, turns out the diameter of these rim's center hole is just under 4-1/4"!!! The outside diameter of those center bullets that I have seen are 3-1/8". Any suggestions? Are there wider ones out there? Should I just be happy with these caps and call it good? Thanks Posted via Mobile Device |
#23 |
I was looking at these. Thought they may work?
http://dandsrodandcustom.com/chrome_bullet_caps Posted via Mobile Device |
#24 |
Anyone??
#25 |
Who Me?
Looks great and good deal.. Cant wait to see them on the truck!
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
| Bookmarks |
| Tags |
| help me please, offset, rims, spacing, wheels |
