Can someone post pics of 18" wheels on stock suspension?
Like the title says. Im about to order some wheels for my truck, but my suspension will have to wait a bit.
Just curious what 18's look like on a stock height C10. Even better if you happen to have a 71 C10 with 18x8's up front and 18X9.5's out back Thanks
71 swb 350/4sp manual 5/7 static drop |
Re: Can someone post pics of 18" wheels on stock suspension?
I have exactly what you're looking for, an stock height photo of a 1971 with 18x8 and 18x 9.5 that I took about 8 years ago, but I can't post photos like a lot of people here right now
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
PM sent... Thanks
When you get the pic from C/10 King, post it here so we can see!
Will do... Im at work.. so if I dont catch it right as it comes in it might take a little bit before I can get to it.
Here's mine currently, tho not the best pic. '72 with 18x8 and 18x9.5 Ridlers at stock height. Doesnt look too bad, but can't wait to drop it.
Posted via Mobile Device |
I think I could live with that for a little bit
Pic sent to email.
what backspacing did/are you guys using? i'm thinking about going to 18s as well ... TexasLS1 your wheels look to sit right at the edge of the body, is that right? any clearance issue? Thanks.
![]() Join Date: Dec 2012
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
here is C/10 Kings truck
![]() Looking pretty good I might add
Thanks, that photo was taken in 06' I believe, the exact tire sizes I might be off a little but the fronts were a 45 series(maybe 255/45/18) and the backs were 40 series (maybe 275/40/18) hope this helps you.
Yes it does.. Thank you
#14 | |
#15 |
![]() Join Date: Mar 2012
I realize this is an old post , but do you remember the tire size for those 18in wheels in the photo??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
#16 |
![]() Join Date: Jan 2016
255-60-R18 on the front and 265-60-R18 on the rear
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
#17 |
