![]() Join Date: Oct 2009
cheyenne AND cheyenne super on the spid...
Interesting SPID on an ebay truck (not mine) http://cgi.ebay.com/ebaymotors/1972-...d76109a9#v4-41
we've discussed this somewheres along the line before, but note that it has both YE9 and Z84 listed as trim options. Interesting, but proof of it for you spid fanatics... (like me). Looks to have all the Super trim except the bright tailgate handle cover (72 slip-on). Anyway, enjoy. |
Re: cheyenne AND cheyenne super on the spid...
Super early 72 St.Louis, sure I'd buy that.
Have a double trim level on 2S103108, Z84 & YE9. While 2S104048 is just YE9.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Cluster King
![]() Join Date: Nov 2012
Now that is one beautiful truck.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Do you guys know what Base Equipment - Rear means?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Those are just standard build equipment lines that more correctly belong on a broadcast/build sheet. Early 72 St.Louis SPIDs were a mess as they changed over to the numeric exception codes from letters then drawn out as they sorted assignments. If you look it also has the base tires listed, four times. Did some research on it about a year ago and the details are a little hazy this morning. If you have them on a SPID I really wouldn't worry about them as they are just a plant variation.
67-72 parts collector,…
![]() Join Date: Nov 2002
Just curious why the glovedbox door is black?
Some plants painted the Cheyenne Super glove box doors black reguardless the body color.
Makes perfect sense...one on each wheel. That is a really nice truck. Posted via Mobile Device
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#9 | |
If optional tires were ordered they were by the axle pair front or rear. Then an optional spare or bare wheel could or would need to be specified be as well depending on the selection. Some tires were offered in full sets of five on one RPO code or line, these were generally white stripe tires.
Moderator
![]() Join Date: May 2007
That truck has the perfect factory color combo!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
