driveshaft help
I've got a 71 swb c10 with a 350/350. I don't have a driveshaft for it. Well, I have one out of a 6 cyl 3 speed. The front shaft on that driveshaft doesn't fit my transmission. Could I swap out the front yoke for one off of an automatic driveshaft?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#2 | |
Re: driveshaft help
http://www.iedls.com/ I used to live in Orlando and Advance Driveline on Carder road is a good place I have used. |
Re: driveshaft help
So if I find a turbo 350 driveshaft I could swap out the yoke, and then have it cut to length?
Re: driveshaft help
You won't need a turbo 350 driveshft IF yours is longer than you need to connect your new trans to the diff. . The driveshaft shop will put your shaft in a lathe, cut off the trans end with a parting tool and install a new yoke that fits your trans and rebalance the shaft. It'll cost about 50.00 for the TH350 yoke (it's a spicer 30 I think) and the machine time to get the shaft to the correct length. Shouldn't cost much over $150.00
Re: driveshaft help
ok, thanks!
![]() Join Date: Sep 2005
Re: driveshaft help
Depending on whT tran the 3 speed is i used the 3 speed yoke on my 71 in my th350 then again in my 4l60e slid right in on all of them
Re: driveshaft help
hmmm... Mine doesn't fit in my TH350.
Re: driveshaft help
Go to junk yard and find drive shaft out of a Chevy truck with a 350/350 combo. And yes the three speed yoke fits a th350. I have the two piece driveline from a three speed and it had a th350 on it.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
