Old 10-09-2013, 08:12 PM   #351
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
5th is the distance of the upper hole from the grease joint.
Old 10-09-2013, 08:13 PM   #352
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Grease joint....
Old 10-09-2013, 08:14 PM   #353
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Hope these helped some what and once you get this side drilled, bolt the sway bar on and you can line up the other side and mark holes as well as the frame. T.J.
Old 10-11-2013, 01:06 PM   #354
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks for the pics TJ. Been out with a cold the last two days. Ill go out and pull some numbers once im better. Good news is the rain finally broke after near a week, so maybe I'll get 30 minutes tomorrow to get the master cylinder installed and the brakes bled.
1964 Short bed trailer
Old 10-12-2013, 10:56 AM   #355
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Nice! When I changed the master cylinder, wheel cylinders, and pads and srings out it made a heck of a difference! One thing for your info, If you convert to a dual bowl master cylinder( front controls front and rear controls rear) then if your brake line goes out you still have brakes.
Old 10-14-2013, 11:38 AM   #356
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Finally got this cold to break...so back on the brakes tonight. MC installed, just have to bleed the lines.
Did get the belts back from the sewing shop....great thing about being close to Ft. Bragg is there are plenty of alteration shops that deal w/webbing due to all the military gear.
Restored a set of OEM buckles that had bad webbing and had some new webbing installed. The new color webbing will match the paint that I will do the interior/exterior in, so they are for another day down the road.
Old 10-14-2013, 03:11 PM   #357
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Those seat belts rock! Nice job! Just gave me an idea. Hope your new master cylinder helps.
Old 10-14-2013, 03:43 PM   #358
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
The OEM buckles are hard to find, and if you find them w/good webbing.....last set I saw was around $450!!
Find some nice salvageable buckles and you can purchase the proper webbing very affordable. I have probably around $80-$100 in mine, which included the rechrome, my paint, webbing and the sewing.
They came out just like new...other than the blue webbing which was not a factory color. All the OEM buckles are color matched to the webbing.
Old 10-14-2013, 03:48 PM   #359
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Mine aren't all that rare cause mine is a 66. Do to a law change cars and trucks came stock with them.
Old 10-14-2013, 09:30 PM   #360
plainred65
plainred65's Avatar
Re: 1963 C-10 in NC
Those seat belts really came out nice Jon. Didn't realize that's what the stock buckle looked like.
plainred65 is offline   Reply With Quote
Old 10-15-2013, 08:35 AM   #361
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Hey Dan, how have you been? Hows the truck project coming? I have some better pics of an unrestored belt 2-3 pages back made by the Irving Chute Co. I have seen a plain buckle w/ a chevy sticker also.....Ill see if I can find a pic in my archives.
Old 10-15-2013, 08:38 AM   #362
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
These are the other belts I have seen w/the stickers. I do not know the specific application...as in if one was dealer vs. factory installed. I just know that both are period correct for the 62-66 models and maybe a few other years.
On the version I have, they are not stickers in the centers. They look to be either cast and welded/glued or maybe part of the original stamping, but its a raised embossed logo.
Old 10-15-2013, 11:12 AM   #363
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Some diagrams that I'll be using soon to replace the seals and weather strips...thought they might be of use to someone else also.
Also found that there were some changes in the 1960 exterior handles that I wasn't aware of.
Old 10-15-2013, 07:43 PM   #364
plainred65
plainred65's Avatar
Re: 1963 C-10 in NC
Finally got an overheating problem solved that's been a tormenting me since I got the truck. Been using it a lot for a remodeling project I have going on so it's all been good.
Your trucks coming along nicely!
Old 10-16-2013, 08:52 AM   #365
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Slowly but surely. I haven't had the time to do the major projects that I want, but Im getting tons of parts restored and ready. Working on lots of little things and of course keeping up with the maintenance.
Old 10-16-2013, 09:09 AM   #366
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got a few minutes yesterday and swapped out the repop floor vent cables for some OEM deluxe cables and knobs. The repops are a nice quality, but the OEM cables complete the knob set to all originals. The only difference I can tell from the two is the OEM knobs look much cleaner and have sharper edges and have the "v" on them. I moved the driver side cable closer to the column, which surprisingly does make it easier to use. I think I like it better next to the column. I left the passenger side in the stock location. Ive been needing to adjust the vents some as I had a little air that would blow by the passenger side, and now Ive got the adjustment perfect. Anyways...heres some before and after pics
Old 10-16-2013, 10:08 AM   #367
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
My next rain day project will be refinishing a pair of vintage 60's BBC valve covers. 3 1/2" total height, so same as what I have now (so shouldn't be any clearance issues). Nice thing is these are aluminum, so they will polish nicely...as a lot of them were made of magnesium. The pair I have now are finned but only on top. These are vintage edelbrock covers w/the chevy logo and finned from one side to the next. Pics to come of the restoration...
The Edelbrock covers will replace the ones on the engine now once polished & painted.
Old 10-17-2013, 11:42 AM   #368
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Found a set of auxiliary springs and the proper mounts...and already restored.
Old 10-21-2013, 03:25 PM   #369
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Ok, event filled weekend, but I got the trans fluid, rear diff fluid swapped, new oil /filter in the block. Got the OEM deluxe choke cable on and the repop pulled off. Got the throttle cable installed and working. And started to do some outside cleaning before it rained on me. Will get pics of the interior dash tomorrow.
Also go the tow bar assembly mocked up and painted, got some new grade 8 bolts for the install.
Start working on the vintage Edelbrock valve covers tonight. Going to polish and paint them.
Old 10-21-2013, 03:35 PM   #370
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Making some dang good progress bud! Can't wait to see the big block in there! New vent cables look awesome! I'm gonna do the same eventually. Dig the seat belts!
Old 10-21-2013, 03:46 PM   #371
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks. Seems all my projects take forever. Some of it is my OCD....everything has to be perfect right!! A lot of it is stuff that's completed and just sitting in boxes because I haven't had time to get around to it. Two jobs, teenager, 2 acres, building a barn...etc. But slowly and surely it'll all get done. Im still enjoying my 12-14 mpg, but I'm more than ready to put the big block in. Last one I had was in a 69 Chevelle SS I had back in 97-98. It had a TH400 behind it and it'd scoot down the road pretty good. Im interested to see how it's going to handle with a 3 speed manual.
And thanks on the seatbelts. I wasn't sure how they'd come out with the OEM buckles being a different color than the webbing, but they really look good. Much better in person than picture.
Old 10-21-2013, 03:53 PM   #372
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
It'll peel those tires like nothin! I'll have to drag race with ya with dad's truck! he's gotta 496 in his! perrty scary!
Old 10-21-2013, 04:05 PM   #373
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Guess I'll get some stock in tires then. hahaha. Very nice 496 your Dad has. How does he like all that hp in a truck?
Heres some pics of the Edelbrock valve covers. Part # 4180
Old 10-21-2013, 06:57 PM   #374
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
It tachs out in all three gears...has a built up turbo 400. 6,000 rpm max. We changed it to a torque cam so it will tow anything we want up a hill at 70! Horse power i think is around 500. Torque 480-500. He and i love the power! He likes it enough to peel out from the gas station just to turn around and re-fill the fuel tanks!!!! HAHAHA!! Were thinking in the future going to a 572....it just keeps getting better! Your new valve overs rock! As well as the ones on there already!
Old 10-21-2013, 07:20 PM   #375
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
thanks. your dads truck sounds like a real screamer. ill probably sell the polished covers currently on the engine
