Old 10-13-2013, 09:10 PM   #1
Black70c10
Black70c10's Avatar
Gauge cluster recommendation please
Hey guys, does anyone have a gauge cluster recommendation for a 70 c10? It's got a sbc with Weiand intake manifold.. Specifically, I'm looking for a voltage, water temp, and fuel pressure 3 gauge combo. I've seen some decent ones from sunpro but I'm curious if anyone has had good luck with any particular units that weren't troublesome with sending units, installation, etc..
Help is greatly appreciated
Black70c10 is offline   Reply With Quote
Old 10-13-2013, 09:37 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Gauge cluster recommendation please
So you are looking for a trio to fit under the dash??? Not sure what you need/want exactly. I have always had good luck with Autometer gauges for aftermarket. As far as a fuel pressure gauge, you really need to run an isolator with it. This will keep the fuel on the engine compartment side of the firewall and the non flammable liquid on the interior side.
I am sure others will chime in also. I can help you if you are looking for a stock gauge cluster.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 10-13-2013, 09:53 PM   #3
Black70c10
Black70c10's Avatar
To be honest, I really only want a new water temp gauge for under the dash but figured a single gauge would look weird.. My stock dash temp, pressure, and voltage gauges all work its just I don't 100% trust my water temp gauge and this is the one I'm most concerned with. I had overheating issues on my last vehicle that completely consumed me, so I'm sort of scarred. I want a gauge I can trust so I was looking for an aftermarket recommendation. Figured I'd get a trio for looks. I'll check out auto meter, thanks!
Old 10-13-2013, 10:13 PM   #4
mmiddle
mmiddle's Avatar
Buy an autometer electric temp gauge and hook it up. Compare this to the stock gauge then remove the autometer. Chances are the factory gauge is working just fine and will continue to work fine.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 10-13-2013, 10:29 PM   #5
Black70c10
Black70c10's Avatar
Good point, may try that approach. Thanks
