Old 12-06-2013, 08:28 AM   #151
jjzepplin
jjzepplin's Avatar
Re: D60 Front Brake Upgrade
Good work sir! This should be a nice rig with some great functionality!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-03-2014, 02:24 PM   #152
DWL
Here are some of my pics. of my calliper brackets i built for my dana 60 using same disks and callipers (2012 ram 3500) also used master from 2007 k3500 callipers are machined out of solid piece 14x14x2 A36 plate then case harden to approx. 56 rc 20-30 thou.deep my reasoning for using a36 was largely cost motivated and seeing that no where on bracket is less than .700 thick failure was not an issue i want to thank mcmlxix for all the useful info.
DWL is offline   Reply With Quote
Old 02-03-2014, 04:05 PM   #153
mcmlxix
Collector of Projects
mcmlxix's Avatar
Those came out awesome! I like them better then my multi piece design that requires welding...
Rich
1972 K5 Blazer CST Click HERE
Old 02-03-2014, 08:51 PM   #154
ryanroo
ryanroo's Avatar
those certainly are sweet! i pondered that same approach when i did mine, but i dont have that kind of skillz on the CNC
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-04-2014, 09:23 AM   #155
jjzepplin
jjzepplin's Avatar
You should reproduce and sell those here.
Dumb question-but you got the calipers and discs from a 2012 Ram-Why wouldn't the caliper brackets from the same truck not fit?
Different design on the Dana 60 years?
Old 02-04-2014, 12:56 PM   #156
70custom20
70custom20's Avatar
It would be great to be able to buy an aftermarket brake kit like this. You can buy just about anything you want for older cars as far as upgraded disc brake kits go, something like this is long overdue for trucks.
70custom20 is offline   Reply With Quote
Old 02-04-2014, 12:59 PM   #157
DWL
Used later model ram disks and calipers because there 14.125 dia. with large dual piston calipers [more surface area,bigger dia.,more stopping power]noticed a big difference in stopping performance
Old 02-04-2014, 01:03 PM   #158
70custom20
70custom20's Avatar
DWL, what kind/year truck did you do this work to? Also, how about the rear brakes, did you upgrade to a rear disc as well, or swap a newer disc brake rear diff into the truck? Thanks
Old 02-04-2014, 01:03 PM   #159
jjzepplin
jjzepplin's Avatar
First things first- SORRY- WELCOME TO THE FORUM!!!!
Now-
Why wouldn't the caliper bracket interchange from the same Ram truck?
Old 02-04-2014, 03:13 PM   #160
mcmlxix
mcmlxix's Avatar
The truck the brakes came from has a unit bearing design and the steering knuckle has the caliper mounting points built into that, no external bracket.
Rich
Old 02-04-2014, 03:22 PM   #161
mcmlxix
mcmlxix's Avatar
It takes a lot to mass produce parts.... it would be simpler and less of an investment to sell the idea (and cad/cnc files) to a company that is in the business to produce a bracket. The best thing he could do is get a copyright patent, then sell the idea...
Rich
Old 02-04-2014, 03:38 PM   #162
whitedog76
I would think mass producing would be a PIA. You'd have to have the parts tested by the NTSB and so on. Not to mention the liability factor. You'd need to be insured out the wazoo.
whitedog76 is offline   Reply With Quote
Old 02-04-2014, 09:32 PM   #163
ryanroo
ryanroo's Avatar
I agree that it would be a pain in the butt. if sold as an off road only type of modification, i think(i have no info to back this) that you could be a little less liable. I know MCMLXIX has been asked to reproduce his, i have been asked to reproduce mine. i am just a little skeptical, and don't care to look into it.
72 K20 12v build
Old 02-04-2014, 11:55 PM   #164
DWL
I agree with the mass producing would be a pia. I did this conversion only because of the challenge of doing it and the concept made sense to me and it works. Its guys like all of us that keep these forums going and enjoyable just thought I'd share what I did . Keep all the good ideas posted as we all benefit!!! CHEERS P.S. someone had asked me what truck it is Its a 99 k3500 crew cab short box,wristed radius arm front suspension rad flow coilovers,1997 5.9 cummins 12 valve ,nv 5600 ,np 205 ,11.5 AAM out of 2007 k3500 single rear wheel. Just started test driving it and knock on wood so far so good Cheers again.
Old 02-05-2014, 12:10 AM   #165
ryanroo
ryanroo's Avatar
thats quite the rig! you should do a build thread in the 4x4 area or the conversions area. id love to see more of your work!
72 K20 12v build
Old 02-05-2014, 12:22 AM   #166
83GMCK2500
Are those dimensions of stock the minimum it would take or can 14x14x2 be minimized? Do you have a model (cad/cam) of those or the g-code?
Those brackets are gorgeous, great job on designing a one-piece solution.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 02-06-2014, 05:09 PM   #167
83GMCK2500
DWL, I am really interested in building a set of these myself but my Dana 60 is a couple hundred miles away and fully assembled yet. I am not in a position to disassemble and take all the necessary measurements, but I am in a position to put some material into a vertical milling center. I would like to upgrade to this disc-over-hub arrangement as well. I would really appreciate the dimensions and from there I could model it and code it. Also, what diameter of wheels are required to clear your setup?
Devin
New Daily, the '96
Old 02-06-2014, 09:57 PM   #168
mckustomfab
^^^^^ x2 ^^^^^
1991 Chevy Crew Cab R3500 to V3500 Conversion Project:
Build Thread
Photo Bucket Pics
You cant fix stupid, and stupid hurt! Rules to live by.
mckustomfab is offline   Reply With Quote
Old 02-07-2014, 07:18 AM   #169
70custom20
70custom20's Avatar
From reading what Rich posted, a 17" wheel is the minimum diameter to clear the calipers. From the pics posted, the wheels barely clear the calipers.
Old 02-07-2014, 08:25 AM   #170
ryanroo
ryanroo's Avatar
i can back that up. i have to leave the calipers and abutments off to use my 16" roller in the garage.
72 K20 12v build
Old 02-07-2014, 11:27 AM   #171
6600DURAMAX
6600DURAMAX's Avatar
I would be in on prchaisng a set of these brackets!!!!
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-08-2014, 10:28 AM   #172
70custom20
70custom20's Avatar
Definitely a market for these parts. I would think a vendor like ORD would be might be interested in purchasing the design and would be able to capitalize on it and sell plenty of the upgraded brake kits. A Dana 44 version would also probably do well. Just my opinion.
Old 02-10-2014, 07:53 AM   #173
70custom20
70custom20's Avatar
A couple more questions for the guys who have made the brake swap, where are you buying the rotors/calipers/ master cylinder from, dealerships? Salvage yards? Or an auto parts store like NAPA? Also, what brake proportioning valve are you using?
Old 02-10-2014, 08:25 AM   #174
ryanroo
ryanroo's Avatar
i got calipers rotors and abutment brackets from one of the local JYs. Mostly for mock up.
i want to get the EBC rotors and pads when i put the axle together for real. at that point i will likey get fresh calipers as well. i have no idea how long these sat out in the yard before i got them. i will be plumbing a wilwood adjustable prop valve in junt in case it needs it. master is from a 95 K2500 and was chosen based on its bore and compatibility with my booster.
72 K20 12v build
Old 02-10-2014, 10:16 AM   #175
mcmlxix
mcmlxix's Avatar
I got my calipers from a JY and had them powder coated locally. Then I put new seals in myself. I am using stock rotors and calipers from a local parts store. I figured I'm already 3 steps ahead with the larger components and parts store quality will be fine. (I understand Ryan's EBC upgrade for the beast that he's building.) I am also upgrading to hydroboost and using a 2005 GMC unit but I did plumb in a Wilwood adjustable proportioning block. I am also running a disc brake rear from a 2004 GMC that has dual piston rear disc brakes.
All this is still untested at this time... I have given up with time estimates as my paint and body guy is taking longer then expected...
Rich
calipers, d60, hydroboost
