View Poll Results: If you had the option, which of these grills would you use? | |||
Original 66 painted grill | 1 | 20.00% | |
64-66 C60 painted grill | 2 | 40.00% | |
an original aluminum grill that needs to be restored | 2 | 40.00% | |
the repo aluminum grill that is now available | 0 | 0% | |
Voters: 5. You may not vote on this poll |
12-06-2013, 09:50 PM | #351 |
Re: pdx-sanity66
I really like where you're going with this truck. A nice dependable drivetrain combination, and a very slick use of other parts from different vehicles. This is my kind of build!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
12-07-2013, 06:09 AM | #352 |
Re: pdx-sanity66
Thanks, Don.
Thanks, man. You did quick work on that suspension mod and the truck looks much better. Sorry on the mix up the way I wrote what I did. I actually just used an 80 grit glass bead and then the rest was hand sanded to the point it is now. I use the cabinet that I made out of a 55 gal drum and I get my blasting media from a local outfit here in Portland. Very inexpensive compared to retail outfits. I think I paid about $10-$15 dollars for a 50lb bag.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
12-30-2013, 02:07 AM | #353 |
Re: pdx-sanity66
I don't really have anything to show for the last week or so but I have been doing a little work on Sanity. My new trans came with a black paint job that didn't match my vision and there was some casting crud on the case so I decided to strip it all off and prep and paint it over with Eastwood's aluminum paint. The stripping and sanding is done but I ran out of time to get it sprayed. I hope to get it done on Wednesday.
Other than that, I chased down some nuts and bolts I needed and cleaned up the shop. Once the paint dries on the trans I'm pretty much ready to get it mated to the engine and get them installed in the chassis.
12-30-2013, 05:03 AM | #355 | |
Re: pdx-sanity66
12-30-2013, 12:42 PM | #356 |
Re: pdx-sanity66
Looks good but.....it is kinda hard to imagine what it looks like...I mean you know....maybe a picture or two...or three....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-02-2014, 10:53 PM | #357 |
Re: pdx-sanity66
Here's the transmission stripped, sanded, and painted. I also bolted up the flexplate to the engine. The trans needs one more day for the paint to cure enough to mess with it. Hopefully tomorrow the trans will be hooked up to the engine and maybe they'll both get moved into their new home between the frame rails.
01-03-2014, 07:36 AM | #358 |
Re: pdx-sanity66
Looks great. What brand are using to hookup the 700R4 throttle valve and lockup with?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
01-03-2014, 05:50 PM | #359 |
Re: pdx-sanity66
Looks good
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
01-05-2014, 04:08 PM | #360 |
Re: pdx-sanity66
Truck looks very nice. I hate to impose on your build thread but do you have a Suburban for sale in the ad section? Please feel free to PM me with info, thank you, Ben.
01-10-2014, 07:53 PM | #361 | ||
Re: pdx-sanity66
Thanks. I'm pretty excited about getting to this stage. Quote:
The latest update. The engine and trans are in. I still have to drill the holes and bolt in the trans crossmember but seeing it all sitting in there gives me great motivation to continue on.
01-10-2014, 07:54 PM | #362 |
Re: pdx-sanity66
We're slowly starting to see the light at the end of the tunnel. Awesome man.
01-10-2014, 11:16 PM | #363 |
Re: pdx-sanity66
Congrats on getting the motor in. Now slap some fenders on and lets go for a ride.
01-10-2014, 11:20 PM | #364 |
Re: pdx-sanity66
Looks awesome. Good motivation for me even though I am way behind you. I'm going in the opposite direction. Just pulled both of mine out.
Bret
01-11-2014, 09:39 AM | #365 |
Watch out for your cornhole !
Re: pdx-sanity66
I don't know how I missed this great thread all this time.
One question though. Earlier in the thread you said you didn't know what ratio your rearend was. How did the transmission man set up your 700R4 speedo gears without knowing what ratio you're running ? The only reason I point this out is that it would be easier to deal with that issue now, rather than later when the trans is full of fluid and you're having to crawl under there and swap speedo gears to get it right.
01-11-2014, 11:14 AM | #366 |
Re: pdx-sanity66
Engine and Trans at home...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
01-11-2014, 03:10 PM | #367 |
Re: pdx-sanity66
that engine and trans looks right at home man!!! it looking good man keep it up
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
01-12-2014, 07:22 PM | #368 |
Re: pdx-sanity66
That engine and trans look like they are meant to be in there! Man that looks sharp! Great work!
01-13-2014, 02:48 AM | #369 | ||||
Re: pdx-sanity66
Thanks, Don. Quote:
Thanks T.J. If you get a chance to get to Portland/Gresham you'll have to stop by.
01-13-2014, 12:01 PM | #370 |
Re: pdx-sanity66
Like the way the trans looks, better than new and it all looks great sitting in there getting ready to go
01-15-2014, 08:39 AM | #371 |
Re: pdx-sanity66
Brett, motor&trany looks killer, that's got to be nice to have them in place. Your truck is coming together very nice, not much longer. I can see you and Joanne getting in it and going to breakfast on a nice Sunday moring, anyway it really does look great and a super good build thread on it, I hope you guys had a good Christmas and a happy New Year! Tell the boys hello from us and I will get my build updated ASAP Reed.
01-24-2014, 06:24 AM | #372 |
UCA63
Re: pdx-sanity66
Looking awesome Brett
Keep up the good work T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
01-24-2014, 10:27 AM | #373 |
Re: pdx-sanity66
Are you going to run a carb or fuel injection?
Bret
01-24-2014, 10:42 AM | #374 |
Re: pdx-sanity66
Looking great. I'm also behind you, at the point of (hopefully) pulling the motor and trans from the frame today .
01-24-2014, 03:07 PM | #375 |
Re: pdx-sanity66
I remember when I was at this stage.... Hang in there buddy.
In the end, it is ALL worth it !!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
