Old 12-09-2013, 09:04 PM   #1
theredmeadow
harmonic balancer replacement
So I have 70 longbed C10 with a 350 stock. Would it be possible to use an impact wrench to remove and reinstall the harmonic balancer without having to remove the oilpan or transmission?
theredmeadow is offline   Reply With Quote
Old 12-09-2013, 09:40 PM   #2
chiefcfd
chiefcfd's Avatar
Re: harmonic balancer replacement
Yes, the balancer goes into the timing cover. You will need a puller for the balancer. I would replace the seal in the cover.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 12-09-2013, 09:44 PM   #3
Longhorn 70
Longhorn 70's Avatar
You shouldn't have to pull the Trans or pan. An impact will work. Or just stop the engine from turning whilst you loosen the bolt with a breaker. This can be done by using a screwdriver through a hole in the flex plate or balance YES! Puller, seal, patience.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-09-2013, 10:30 PM   #4
Sammy
Making a deposit and using the rental tool program at Autozone for free why not use the right tool?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-09-2013, 10:34 PM   #5
LONGHAIR
You can use it to remove the bolt that holds it on, but that's just the start.
You need a puller to get it off and an installer to push it back on. These can be "borrowed" from many autoparts stores.
Don't try to put it back on with the original bolt. First of all it will be too short to reach or only catch by a few threads, likely stripping the threads.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-09-2013, 10:35 PM   #6
theredmeadow
And just so I understand, the impact will allow me to push the balancer back on without having to stop the engine from turning via wedging an object somewhere?
also, would this be ok to replace it?
http://www.summitracing.com/parts/rn...FQISMwod3FcAwA
can you link me the seal you're talking about? I'm no mechanic so any info i can get is much appreciated.
Old 12-09-2013, 10:40 PM   #7
Longhorn 70
I would use a rachet to tighten, then torque wrench to spec to put it back on.
Old 12-09-2013, 10:41 PM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Get the correct puller and installer for this job. I attached a photo of the seal kit. You can buy the seal separate from the kit for under $10.00 anywhere.
If you are not familiar with this task, I would NOT use air tools to perform the job.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 12-09-2013, 10:44 PM   #9
theredmeadow
ok cool thanks. Ok I understand I'll need the puller to get it off and a tool to push it back on. I saw a video where the guy used the tool to push it back on but he mentioned that if you dont stop the engine from turning that the balancer will just spin in place.
Old 12-09-2013, 10:57 PM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
If that is the case and it is very possible, then all you need to do is clamp a pair of vise gripes on the flywheel/flex plate and that will prevent the crank from spinning all the way around.
Old 12-09-2013, 11:49 PM   #11
mmiddle
mmiddle's Avatar
DO NOT use the retaining bolt to push the balancer back on!!!!!!!! If you do you will be removing the balancer again to Heli-coil the crank. Use a new bolt and anti-seize, they are cheap.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 12-10-2013, 09:14 AM   #12
cdowns
cdowns's Avatar
why do you think there is a need to remove your balancer?
Old 12-10-2013, 09:21 AM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
+1... from experience...
Yes, why do you think it's bad? Vibration? Seal leaking like crazy?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-10-2013, 11:25 AM   #14
theredmeadow
yes vibration from the engine, it starts around 45 and really vibrates after that.
Old 12-10-2013, 11:27 AM   #15
67ChevyRedneck
That might not be the motor. Can you replicate it with the truck in park or Neutral?
Do you have a timing light? If you know about where the timing should be at idle (should be somewhere around 8 to 12* BTDC), if it's moved a lot that could mean the outer ring on the balancer has slipped and is causing the vibration.
Jesse James
Project "On a Dime"
Old 12-10-2013, 11:49 AM   #16
theredmeadow
actually I haven't checked to see if it vibrates in neutral or park. I will check that, if it doesn't I'm assuming we may be looking at maybe unbalanced drive shaft?
Old 12-10-2013, 12:06 PM   #17
67ChevyRedneck
Or bad u joints.
Jesse James
Project "On a Dime"
Old 12-10-2013, 12:17 PM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by 67ChevyRedneck View Post
Or bad u joints.
Or center carrier bearing if it has a two piece drive shaft. You can visually check the carrier or try pushing the whole drive shaft up and down in the center...
LockDoc
Leon
Old 12-10-2013, 03:33 PM   #19
Chris Binnett
Use the tool from O'rieleys/Autozone, but slap grease all over the threads and the bearing on the front, as well as the inside of the new HB. There is no need to wedge the motor if you have two wrenches. One goes on the end of the threded rod to keep it from spinning and the other one turns and pushes the balancer on. That guy in the "Toolbox" video on youtube had a WAY tougher time than I did.
Grease and oil EVERYTHING and stop the motor from spinning with a second wrench...easy!
C
1971 Cheyenne Super LB, Built factory 402. Rollin' WHITE on WHITE
Chris Binnett is offline   Reply With Quote
Old 12-10-2013, 04:02 PM   #20
Longhorn 70
Could also be motor mounts...
Old 12-10-2013, 05:10 PM   #21
old Chevy guy
old Chevy guy's Avatar
If it does it in neutral it could be a tire . Or like the guys said u joints. my box truck picked up a wicked vibration and it was the center joint. Started around forty and got worse the faster it went.
old Chevy guy is offline   Reply With Quote
