Junior Member
![]() Join Date: Jun 2007
How to mount voltage regulator
I know this might be a dumb question but.....How does the voltage regulator mount on our trucks? I took the old one off about a year ago (the rubber mounts disintegrated while removing the bolts) and set it aside while I did other things. I ordered a mounting kit which came with 3 screws and 3 t-shaped rubber grommets about 3/4 inches long. I seem to remember the factory grommets being H-shaped (sandwiching the core support). Any one know how the new kit mounts or did I get the wrong part - DOH
"A man's got to know his limitations." - Dirty Harry _______________________________________________ 1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker |
Re: How to mount voltage regulator
Old post but I am wondering about this myself. Can't seem to figure out how they mount. Thanks
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
![]() Join Date: Oct 2013
if new, hopefully, there should be instructions in box
Regulator came with instructions but doesn't show how to mount the rubber insulators.
![]() Join Date: May 2010
What you have is correct. The T-shaped grommets are actually well nuts. Put them into the holes in the core support from the engine side. They should be barely snug. Insert the screws through the regulator base and screw them into the well nuts. As you tighten them the well nuts expand.
#6 | |
