Old 01-28-2014, 05:05 PM   #1
Double_C
Hazard Switch
Hey Guys,
New to the forum, but have been playing with my C10's for a while.
My question to the groups is. A 1971 C10, which type of hazard switch should it have. The Red style or the black mushroom style.
Thank you for the help in advance
Double C
Double_C is offline   Reply With Quote
Old 01-28-2014, 06:50 PM   #2
71Dually
71Dually's Avatar
Re: Hazard Switch
My 71 C/30 has a red one
The interior is original (except later model Chevy steering wheel, CB and Pioneer Supertuner).
Even though I've got a C/30 I figure a C/10 would be the same. Don't know if there was a midyear change but my truck was built in April 1971 if it matters.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline   Reply With Quote
Old 01-28-2014, 07:01 PM   #3
Double_C
Re: Hazard Switch
71 Dually,
Thanks for the photo and the information.
I found a 4 speed tilt column that I'm going to install, and I found a company that sells the Red switch style turn-signal assy., just trying to make it look correct.
Old 01-28-2014, 09:03 PM   #4
NC_John
NC_John's Avatar
Re: Hazard Switch
Originally Posted by Double_C View Post
71 Dually,
Where did you find it? I need to replace my broken one.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-29-2014, 11:44 AM   #5
Double_C
Re: Hazard Switch
NC_John,
A company in CA called M&H electric has replacement harnesses and components
Old 01-29-2014, 01:10 PM   #6
FirstOwner69
FirstOwner69's Avatar
Re: Hazard Switch
71 Dually,
I'm not sure the tilts used the red switch. You may want to hold off until you get more responses. I have found 3 true truck tilts in the last few years. None had the red switch. KevsClassics is an expert on these. You might try sending him a PM.
http://67-72chevytrucks.com/vboard/s....php?p=4250625
FirstOwner69 is offline   Reply With Quote
Old 01-29-2014, 01:59 PM   #7
70shortfleet
70shortfleet's Avatar
Re: Hazard Switch
The truck tilts do not use the red flasher style. They use the black style or there is a chrome flasher knob that looks great!
70shortfleet is offline   Reply With Quote
Old 01-29-2014, 03:57 PM   #8
FirstOwner69
Re: Hazard Switch
Here's a picture of the chrome knob 70shortfleet mentioned installed.
Old 01-29-2014, 10:19 PM   #9
NC_John
NC_John's Avatar
Re: Hazard Switch
NC_John,
Thank you sir- I helped install an M&H harness last weekend.
1970 C-10 LWB "Blu"
Old 01-30-2014, 12:26 AM   #10
seattle gmc
seattle gmc's Avatar
Re: Hazard Switch
Sorry to too high jack the thread but this might help out some other poeple. My red hazard nob is broken and i would like to replace it. Is there a way to replace just the knob, or do you have to replace the whole switch. The turn signal swtich with red knob was 42.00 at M&H.
seattle gmc is offline   Reply With Quote
Old 01-30-2014, 06:25 AM   #11
NC_John
NC_John's Avatar
Re: Hazard Switch
That's what is wrong with mine- the red button was dry rotted/brittle from age and just snapped off.
I went through the M&H site but didn't see the hazard switch. What's the PN? I haven't been able to find a repop of the original red button by itself, just the round black ones....
1970 C-10 LWB "Blu"
Old 12-03-2020, 12:53 AM   #12
nicklear36
nicklear36's Avatar
Re: Hazard Switch
Will that chroma known work with a non tilt column instead of the red one?
nicklear36 is offline   Reply With Quote
Old 12-03-2020, 10:49 AM   #13
70shortfleet
Re: Hazard Switch
Yes, you will have to get the wiring harness that excepts the screw in chrome knob not the red knob that is built into the harness.
Old 12-03-2020, 11:25 AM   #14
nicklear36
nicklear36's Avatar
Re: Hazard Switch
That is the tilt column turn signal harness? Will that still work with the non-tilt? Thank you!
Old 12-03-2020, 12:37 PM   #15
70shortfleet
Re: Hazard Switch
Yes, it will work in the non tilt column. Buy this switch from Parts-N-Things and just remove the indicator light. https://www.ebay.com/itm/1967-1972-C...53.m1438.l2649
They are even located in Oregon
Old 12-03-2020, 01:17 PM   #16
nicklear36
nicklear36's Avatar
Re: Hazard Switch
Thank you for leading me to it!!
Old 12-03-2020, 09:10 PM   #17
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Hazard Switch
Sorry guy's but yes the tilts use the red flasher knob. I have them in both my trucks. I have the factory tilt in my 71 C-10 that I took out of a Blazer 30+ years ago and it had the red knob.
https://67-72chevytrucks.com/vboard/...d.php?t=733325
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-04-2020, 10:11 AM   #18
70shortfleet
Re: Hazard Switch
Andy, just because your 2 tilts have the red hazard knobs doesn't mean that they came that way from the factory! Let's do a poll of everyone that's had a factory tilt column and you will see that from the factory they used the black hazard knobs. I've had about a 100 tilt columns and at least 95 of them had black knobs on them.
Old 12-04-2020, 10:47 AM   #19
Andy4639
Old member
Andy4639's Avatar
What ever man. I just know they came with them. I grew up riding in them and the black ones never came in these. Unless they were motor homes are vans. The c-10 had the red ones. My dad drove these trucks all my life and never saw a 72 -71 with a black e switch...never.
Pole doesn't prove anything except what people believe, just like the brake pedal having 2 holes in it. Never happened from the factory.
Old 06-15-2023, 04:17 PM   #20
72GreenMonster
72GreenMonster's Avatar
Re: Hazard Switch
72 GMC red hazard switch from the factory. Broken also.
72 GMC Sierra 2500
72GreenMonster is offline   Reply With Quote
