Old 01-29-2014, 10:16 AM   #1
Builtwright
Post custom rear trailing arms
Has anyone on the forum fabricated their own rear trailing arms? Been tossing the idea around
Builtwright is offline   Reply With Quote
Old 01-29-2014, 11:18 AM   #2
KMC3420
KMC3420's Avatar
Re: custom rear trailing arms
This guy did, post #36.
http://67-72chevytrucks.com/vboard/s...=316300&page=2
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-29-2014, 11:21 AM   #3
Grumpy old man
Grumpy old man's Avatar
I have been considering it only because I have a friend with a heavy fabrication shop and the right equipment to drill tap and thread the forward end to use Heim joints and the heavy press to achieve the proper aft bend and correct welds to hold it all together and make them track correctly .I will have to call him today and check on the correct materials and how many cases of beer it will take !
Old 01-29-2014, 11:22 AM   #4
Builtwright
Awesome, thanks! Was thinking about building a set with some built in drop
Old 01-29-2014, 07:05 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: custom rear trailing arms
Other than just for the cool factor that you did them your self, there are several vendor on here who make them just for our trucks. Even with the blocks attached.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-29-2014, 07:29 PM   #6
BMERDOC
BMERDOC's Avatar
Heres is Nuke1's how-to:
http://67-72chevytrucks.com/vboard/s...d.php?t=321100
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-29-2014, 08:00 PM   #7
Builtwright
I just prefer to make my own stuff
