Old 02-11-2014, 09:18 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink New rotors
Ok I bought the rotors and did some measuring on them. As stated they wouldn't fit to the Boss 338 wheels I have so I took them yesterday to have the hubs machined down to fit. I should have them back tomorrow I hope.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-14-2014, 08:34 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: New rotors
Well I finally got the rotor's back. Drivers side is done. They fit good and all cleaned up. I still had to grind the end of the hub down for the wheel cap to fit.
Old 02-15-2014, 07:14 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: New rotors
Both front rotors installed with new bearings again, I just did them back last May before the Power Tour. Front end all greased and cleaned up.
Old 02-16-2014, 06:55 PM   #4
mikeshome
mikeshome's Avatar
Re: New rotors
Something does not seem right if you need bearings again if you did them less than a year ago!
mikeshome is offline   Reply With Quote
