Old 02-16-2014, 03:02 PM   #1
Black70c10
Black70c10's Avatar
Truck won't idle below 1000 RPM all of a sudden
Hey guys, I'm having a lot of trouble all of a sudden with my trucks idle. It used to idle just fine all day at 500 rpm with timing 18 before TDC. Had he timing a little closer to tdc but it would bog down under WOT so i found that this timing worked the best. Out of no where after changing the oil yesterday, the thing will not idle below 1000 rpm, it will sputter and die. I cannot seem to locate the issue. I have not made any adjustments to the timing and or idle mixture screws.
t's a small block with an edelbrock 600. Anyone have any insight into this issue?
Black70c10 is offline   Reply With Quote
Old 02-16-2014, 03:06 PM   #2
72_swb
72_swb's Avatar
Re: Truck won't idle below 1000 RPM all of a sudden
Did you knock off a vacumn line maybe. just a thought
72_swb is offline   Reply With Quote
Old 02-16-2014, 04:26 PM   #3
Black70c10
Black70c10's Avatar
Yeah I thought about a vacuum leak but I don't see anything that was disconnected.. Very bizarre what's happening.. I played with the idle mixture just a little bit and it will now idle around where it used to (500-600) but it's definitely not right, it's acting a little erratic. When you bump the throttle it won't come down quickly in RPM like it used to, it will go up in speed and then hesitate and slowly come down in speed. I took it for a spin around the block and when you ease into the throttle it hesitates for a fraction of a second before a slight jolt forward in speed... It's fine under WOT but off the line it will hesitate and the idle just seems rough. Up and down maybe 50-100 RPM randomly... Sounds like a vacuum leak but I don't know! Thoughts?
Old 02-16-2014, 04:56 PM   #4
Sillyoldman
#16876
Sillyoldman's Avatar
Vacuum leak comes to mind first.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 02-16-2014, 05:01 PM   #5
boynton
boynton's Avatar
I would agree. You can take your air cleaner off start it up and cover the top of the carb with your hands if it starts to idle correctly then you have a vacuum leak. My carb had a leak inside and I couldn't figure it out put a spare carb on and it ran like a champ.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-16-2014, 05:01 PM   #6
1972RedNeck
1972RedNeck's Avatar
Get some WD-40 and spray around the carb. If you're bored, use ether.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-16-2014, 06:40 PM   #7
Black70c10
Black70c10's Avatar
Thanks for the help guys, I'll try that. I'll check all around, hoses to and from valve covers, brake booster, carb, etc.. Let you know what I find.
