Old 02-17-2014, 10:50 PM   #1
cb1965
cb1965's Avatar
control arm bolts ?
i have a 66 C10 with a 75 front suspension. one of the bolts that holds the upper control arm is stripped and need to know if this will fit ?
http://www.classicparts.com/1971-91-.../#.UwLJmPldWPA
can i get it at a local store?
thanks
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 02-18-2014, 01:24 AM   #2
Captainfab
60-66 Nut
Re: control arm bolts ?
That looks like the correct type of part, but that part numbner shows to be for a C20 or C30.
Old 02-18-2014, 11:10 AM   #3
cb1965
cb1965's Avatar
Do you know if it will fit? I haven't found anything for C10's.
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-18-2014, 12:06 PM   #4
Sharps40
Couple issues. You should be able to go to Napa or other supplyer and find a similar stud. The problem comes with pulling and replacing....is there room to press a new one back in.
Sharps40 is offline   Reply With Quote
Old 02-18-2014, 12:18 PM   #5
Sharps40
I think you want part number 7 from LMC....this is for 60-66 models. $3.95 each + Shipping.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=86
And looking at the schematic, seems you might just be able to beat em in and out without droppin the crossmember but I spect ye'll have to pull a motor mount. Luck!
Old 02-18-2014, 09:18 PM   #6
cb1965
cb1965's Avatar
hey sharps, do you think that will work with a 75 crossmember?
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-18-2014, 09:38 PM   #7
Sharps40
Don't know. Go to the lmc catalog and see if the bolts have the same part numbers for 66 and 75. If not take your bad bolt to napa and they can get in the catalog and order ya one or 100.
Old 02-19-2014, 12:09 AM   #8
cb1965
cb1965's Avatar
Ok. Yea I just saw it on the lmc catalog. Thanks
'66 chevy lwb c10
'65 chevy lwb c20
