![]() Join Date: Nov 2013
Our truck big blocks......4 bolt mains??
Since they were truck motors and I do not want to take mine apart to inspect it....were the truck big blocks 4 bolt mains?
Re: Our truck big blocks......4 bolt mains??
I'm gonna go with 2 bolt. I'm almost positive my 71 402 was a two bolt main
![]() Join Date: May 2013
my guess would be 2 bolt , they are 1/2 inch bolts
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
No if you're referring to light duty trucks 1/2 and 3/4 ton. Only high performance cars, those with the large square port heads got 4 bolt blocks. The heavy duty trucks with tall decks may have had 4 bolt mains but I think most of those were two bolt also.
The only 396/402 engines with 4 bolt mains were the L78 Corvette and Z16 Chevelle motors. All of the C-10 trucks were 2 bolt main bearing engines.
Florida Edition
![]() ![]() Join Date: Oct 2010
2 bolt...here is my original 70 402 for reference.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
As has been said countless times ... don't get yourself all bunched up over stock 4-bolt set ups. Unless the outer bolts are splayed, there is little to no advantage.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
While on this topic, what about the crank shaft? I recently rebuilt a 1972 402 out of a C-20 (was told it was the original, but I don't think it was) and when I pulled the crank and dropped it off at the machine shop, the guy looked at me and asked what the crank came out of? It was forged steel, cross drilled and hardened? He said most cranks he cuts from that generation are cast
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
