03-05-2014, 10:23 AM | #1076 |
Re: intro + 66 black bagged long fleet
well I still have time. I just got my 65. So all the possibility research and questions are flying right now.
Anyone know if they sell drop spindles for the 65 so tou keep the six lug and drum brakes?
1965 C10 Project |
03-05-2014, 01:14 PM | #1077 |
Needs a Big Block
Yea , you can use newer drop spindles, say 73-87. And there are aftermarket 6 lug rotors that will slide right on.
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
03-08-2014, 10:01 AM | #1078 | ||||
ive been slacking lately so im still not done with them...i will get more pics when i finish them up Quote:
sorry man ive been slacking big time on my build thread lately. ive been getting alot done this past week so it will be a runner again in no time Quote:
i just got some new ones the other day updates real soon.. the engine and trans are back in..
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
03-08-2014, 10:10 AM | #1079 | |
and yes, been tattooing for the past 23 years
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
03-18-2014, 06:31 PM | #1080 |
o sweet man its always cool to see another artist do you have a website or anything? what shop do you work at?
well sorry not many pics but a lot of work has been done lately.. here is a short list of other mods i did to make the engine fit how i wanted it to without the oil pan hitting the ground when layed out. installed 8" deep oil pan (had a 9" pan) spaced the engine mounts up 1/2" and slotted the holes a little more to move the engine back a 1/2" also (needed more room for a flex fan) the crosslink for my steering was hitting the oil pan so i had to mod it to make it fit (picture below) modified the tranny crossmember for more room for the exhaust and also made it two peices cause it was near impossible to get it in and out without removing the exhaust. here are a few pics tranny crossmember mod. since i made it thinner i welded some flat stock on the front and back to help beef it up. It is super easy to install now everything is hooked up and ready to go except for the radiator. I had to move the mount and little bit further forward to clear the new fan.. btw i went with the flex fan because at idle it would start to heat up with that electric fan. i plan on running both fans just in case. i also added a different tranny cooler instead of trying to use the radiator to cool the engine and tranny so it should be good to go now new tranny cooler. not real sure if i need a fan on this??? i was thinking of making a little scoop that will direct air toward it while going down the road. anyone have experience with one of these? steering u joint welded in place. installed new bearings in the column and shortened the shaft an inch shorter than stock so i could adjust the column more forward to get the steering wheel further away from me here is the steering crosslink after i modded it.. i welded it back together then went overkill by adding gussets and boxing it in all the way around where it was welded together cause i dont wanna take any chances all i really have left now is finish the wheel tubs. mod my hood hinges some more and install the front clip and radiator
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 Last edited by coulter; 03-18-2014 at 06:45 PM. |
03-18-2014, 06:57 PM | #1081 |
You have been busy...
03-18-2014, 07:07 PM | #1082 |
Lone Star Round Up?
03-19-2014, 12:54 AM | #1083 |
Looking great.
Rob
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=578272 https://www.instagram.com/fb_garage/ |
03-19-2014, 04:32 PM | #1084 |
Kool man. I have been hoping everyday we would see some updates. Killer work as always.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-19-2014, 04:41 PM | #1085 |
Very nice fab work and mods. Killer build you have going on.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-22-2014, 06:51 AM | #1086 |
Hey Coulter I just got to say ur a bad ass! I really dig what u've done and ur bike's r bad ass to! I got a road king that I've always wanted to suicide, but anyway u've given me a lot of new ideas! Thanks this tread has been inspiring to me!
03-23-2014, 11:45 AM | #1087 |
I'm digging the updates, truck is looking good!! tattoos look bada$$, I don't have any experience with the trans cooler, but I just got my 18" dual pass one in the other day, haven't installed it yet either! I shortened my steering column 3in. also haven't finished that yet, I got a list of things I got to get done since I have a garage now
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
03-26-2014, 01:49 PM | #1088 |
I believe that this is the longest build page that i have read from start to finish! It only took me 3 days i never have more than a few minutes at a time! You have some SKILLS FOR SURE!!
04-06-2014, 03:01 AM | #1089 |
thanx for all the compliments and taking the time to read the whole thread
well the truck is running again and im just about done with everything. sorry ive been slackin on the updates..i went for a cruise today and snaped a few shots real quick. i didnt take any of the new front wheel tubs since i got them done but i will get some tomorrow and im gonna post a few progress pics from the last few weeks also i got my rear cokers today. i couldnt be happier with the sizes of the tires i picked and the new stance!!! i love it anyway here are the ones i took today
04-06-2014, 03:22 AM | #1090 |
As usual Coulter, you have the best pics on here.
04-06-2014, 06:44 AM | #1091 |
Awsome truck, and damn what lovely pics.
04-06-2014, 11:15 AM | #1092 |
Awesome pics.
04-06-2014, 12:20 PM | #1093 |
Rollin' Old Skool
Cool pics, & the truck continues to look more killer each time you post!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-06-2014, 12:36 PM | #1094 |
Nice Ride lots of work!
04-06-2014, 01:59 PM | #1095 |
Nothing I would change. Love the truck, love the look. Killer work as always.
04-06-2014, 02:40 PM | #1096 |
thanx guys!!!!! here are the pics of the wheeltubs i promised.. plus a few bonus detail shots
[IMG]https://farm4.staticflickr.com/3686/13673115413_cc1dae24c4_c.jpg [/IMG] welded both sides had to do some rust repair filled in the cutout about 1/2" to make it less noticeable that i lowered the bumper and here is how they turned out dont worry ive got a cool idea on how to get my centercap mounted up since it wont fit right now.. that is coming soon i used stainless this time for the trim peice so i can polish it up had to trim the hinges even more. i welded on some 1/8th thick x 1/2 wide flat stock to beef it up a little bit. also drilled some holes to make it match the latch plate. ok here are all the bonus shots! enjoy [IMGhttps://farm8.staticflickr.com/7216/13673085085_bd70cbcfac_c.jpg[/IMG] [IMGhttps://farm4.staticflickr.com/3797/13673129033_3b4bed22f5_c.jpg[/IMG] thats all for now.. dont worry i still have plenty of ideas coming soon
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 Last edited by coulter; 04-06-2014 at 02:45 PM. |
04-06-2014, 02:47 PM | #1097 |
Well.
No wonder you been so quiet around here, busy busy !! Your work is so ....... wow. Yep, thats all I got
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-06-2014, 03:00 PM | #1098 |
haha ya ive been working like a mad man lately. i dont want to miss out on any more shows!!!
04-06-2014, 03:54 PM | #1099 |
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-06-2014, 08:29 PM | #1100 |
Looks great. I like the drilled hinges.!
