Closed Thread
Old 03-14-2014, 02:19 AM   #301
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: What did you do to your truck today part II.
Originally Posted by 1971 GMC SHORTY View Post
More Rust
Guess Not To Bad
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline
Old 03-14-2014, 08:01 AM   #302
MikeS.
MikeS.'s Avatar
I'm heading outside to start pulling off chrome and handles and the like. My 63 Burb goes off for paint Monday.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline
Old 03-14-2014, 09:20 AM   #303
tincan1966
tincan1966's Avatar
Removed my rear air bags yesterday and put in a set of 3" drop rear coils. Hoping to fab up a watts link over the weekend and get rid of the original bar. Installed some Marshall 2 5/8" gauges. Hoping to get the bed liner sprayed too during this nice weather we are having. Then bodywork and paint, all in hopes of making a May 10th show we will be at as a vendor.
tincan1966 is offline
Old 03-14-2014, 10:50 AM   #304
Robert Haas
I ran out to Laguna Seca and bought a fresh drum of Sunoco 104. Gonna cruise over to Monterey tonight and scare some tourists.
Robert Haas is offline
Old 03-14-2014, 03:39 PM   #305
pimpston65
pimpston65's Avatar
dragged my machine up to my loft and snagged another harrison rad for $20 on the (e)bay yea!!!
pimpston65 is offline
Old 03-14-2014, 03:42 PM   #306
pimpston65
pimpston65's Avatar
my GM rad says its from a pontiac or oldsmobile anyway is the same shape and size 3 core and for an auto trans non ac
Old 03-14-2014, 08:04 PM   #307
TJ's Chevy
TJ's Chevy's Avatar
Hauled fertilizer with mine today. Also gave her a bath.
TJ's Chevy is offline
Old 03-14-2014, 08:32 PM   #308
Improbcat
Improbcat's Avatar
Dragged the truck out of the yard where it has been sitting all winter and into the garage. Started dis-assembling the front end to start rust repair. One fender took an hour and involved cutting three bolts and snapping one more.
There is a *lot* of rot on the fenders, radiator support & front panel. Going to be interesting fabricating it all.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline
Old 03-14-2014, 10:22 PM   #309
Old Truck Man
Old Truck Man's Avatar
I had the same problem on my GMC (Zombie truck). Luckly I have a quanity of spare parts. So I picked out some mediocre parts that where dented but not rusty pounded out the dent,s and changed the complete front cap. Just my opinion but it think For the time it will take you to repair yours if you paid yourself 50 cents an hour you could buy new parts.
Old Truck Man is offline
Old 03-15-2014, 01:12 AM   #310
64chevtruck
Hi, Id like to second what OTM said, You may want to just get some used parts to save a lot of time, I do like your enthusiasm though.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline
Old 03-15-2014, 09:15 AM   #311
Improbcat
Improbcat's Avatar
I have been searching for used parts around here for months, with little luck. Pretty much everything in the northeast is just as rusted, or they want thousands of dollars for what I would call a parts truck. Metal and welding wire is relatively cheap compared to the $900+ aftermarket parts would be(not counting the inner fenders even), so I figure it'll be good practice to try doing it myself.
Old 03-15-2014, 10:41 AM   #312
Chevy Fleetside
Chevy Fleetside's Avatar
I got my gas tank the other day. The Fed Ex guy brought it to me.. yay. I started putting it together and have the sender set up to go in next.
I removed the spare Tire from my truck (which is an L78-15 Sears Bias-Ply Tire. I think it is dated as Jan 1988) drilled out the rivits to the retaining bar and that is pretty much where I am at now. Hoping to install the tank in the next few days and get the stock one out of the cab. Yes it stinks in there after putting fuel in.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 03-15-2014, 12:27 PM   #313
Itnkrman
Here's the universal TBI tank installed between the frame rails of my 62. I also took the opportunity to wire loom frame wiring, paint the frame, install new 3" drop coil springs (2" blocks already installed), relocate the exhaust to discharge out the side(instead of under bed blowing on tank), change the cab bushings, paint the inside of the bed flat black and install a "new" custom wood floor.
Itnkrman is offline
Old 03-15-2014, 01:18 PM   #314
Old Truck Man
Around here the trucks mostly rust out below the battery box and its hard to find a rust free radiator support, also at the bottom of the front fenders and rockers. On yours it appears that you still have the very front bolt holding the front fender. That bolt is a real pain to remove. Ive drilled a 1/4 inch hole in the fender and used a 1/2 drive extension ratchet & 1/2 six point socket to remove it. Just braze or weld the hole up. I never install that bolt when I put one back together. We once bought a truck that came from Chicago. It looked fine. It has made from bondo. My son stated they must have purchased their body filler by the 55 gallon drum.
Old 03-15-2014, 03:48 PM   #315
Chevy Fleetside
That is the tank I have also... I got mine from this guy. http://www.leadmineproducts.com/servlet/StoreFront . He was the same price as everyone else but with free shipping... He sent me a wrong part and I e mailed him and he put it in the mail for me. Good Service and I will definatly use him again if he has soemthing I need.
Old 03-16-2014, 08:40 PM   #316
endlessearth
endlessearth's Avatar
Fired up the new motor for the first time. I will load the video later. It sounds healthy to say the least.
endlessearth is offline
Old 03-16-2014, 10:36 PM   #317
tonythezeek
tonythezeek's Avatar
not really today but more like the whole weekend.
Started off Friday evening by placing the fuel cell between the rails in the rear. Then went on to running new fuel line from the rear of the truck to the front. Had to chill out for the day because I let a friend borrow one of our vehicles and was stranded at the house (needed parts).
The next morning, went to the hardware store and bought enough nuts, bolts and washers to choke 5 evil donkeys and a stubborn mule. Also picked up various fittings and hoses. When I got back home, it was time to bolt everything in place. I also took out the old, in cab fuel tank and modified my transmission hump (running PB gear up front).
Ran a few pounds of pressure to the temporary air lines and tires, cranked it up, and drove it out of the garage. She also took her first steps on the road but was cut short due to some bad lug nuts and no tags. But all in all, a very successful outing. She did get a bit fussy about going back into the garage though... which leads to the laundry list of items I need to do before making her truly road worthy (both known issues and some surprises).
Cleaned myself up and headed out (minus truck) to a car show they have every third Saturday of the month. ...I now have a target due date.
..and the oil spot in front is from the Blazer... she was being a diva that day too!
tonythezeek is offline
Old 03-17-2014, 01:55 AM   #318
endlessearth
The pusher lives. First start today.
https://www.youtube.com/watch?v=kEQsI5koXXs
Old 03-17-2014, 06:49 AM   #319
MikeS.
MikeS.'s Avatar
Sounds real good.
Past Master
MikeS. is offline
Old 03-17-2014, 06:51 AM   #320
MikeS.
MikeS.'s Avatar
Took her off to be painted yesterday.
Past Master
MikeS. is offline
Old 03-17-2014, 08:45 AM   #321
earl84
That sounds SWEET!
earl84 is offline
Old 03-20-2014, 05:39 PM   #322
Old Truck Man
I removed the west coast mirrors. installed a chrome front bumper. Went and cut a load of fire wood and tested it out.
Old 03-20-2014, 07:32 PM   #323
TJ's Chevy
TJ's Chevy's Avatar
Had to move my truck outta the way of the back hoe attachment so I could install it on the tractor. Took some pictures while I was at it. Showing off my sign "Chevy Truck Parking Only." lol.
Old 03-20-2014, 10:00 PM   #324
raic65
raic65's Avatar
Got new tires. 345/30r19 on all 4 corners.
Only to tow the truck home because I had too thick of a front wheel adapter.
But when I finally changed it, everything cleared.
raic65 is offline
Old 03-20-2014, 11:21 PM   #325
Softpatch
Softpatch's Avatar
wow how does that work .? tubbed.?
I have 245 50 16 and don't think i could go any large on rear stock setup
....sp
picked up paint for interior
Softpatch is offline
Closed Thread
