Old 04-08-2014, 09:42 AM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Late Model Exhaust Manifolds
Has anyone here used this style exhaust manifolds on our trucks? If so, any interference problems (column-auto)? I am thinking about replacing my ram-horns with this type. It sure looks like spark plug access is much easier with these???
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 04-08-2014, 11:51 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Late Model Exhaust Manifolds
No can do.
They won't even come close to bolting on because of interference with the engine mount stands.
Draw an imaginary line front to back through the bolt holes. Then look how far they hang below that line. Now, look at your truck and you'll see what I mean.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-08-2014, 12:01 PM   #3
71K20chevy
71K20chevy's Avatar
Don't replace your ram horns. They flow really good compared to the log style!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 04-08-2014, 01:38 PM   #4
kwmech
They will fit IF, you install the big block stands which moves the engine REARWARD about 1-1/2''. If not ramhorns or headers
Old 04-08-2014, 04:50 PM   #5
Tx Firefighter
Or 73-87 mounts....
Old 04-08-2014, 04:51 PM   #6
kwmech
Or that ^^ also
Old 04-08-2014, 06:36 PM   #7
myyamr7
myyamr7's Avatar
I just swapped from a small block to a big block, replaced the small block stands with big block stands and the engine sits in the exact same position as the small block. Just a for what it's worth post.
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 04-08-2014, 07:44 PM   #8
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Also, if you are using an older block(driver's side dipstick),you may run into problems using your stock dipstick. I tried a set of 85ish on an old block and they completely covered it when i pulled the tube insert.
mblackburnjr is offline   Reply With Quote
