Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 04-15-2014, 10:31 AM   #1
stroker87
Thumbs down MDS STINKS waist of money!
I have a full MSD ignition on my 1987
6AL box x2
blaster coil x3
pro billet distributor x2
MDS cap & rotor x3
8.5 wires x3
Ignition modules x4
in the last 6 years I have less then 4,000 miles on all of this plus it all sat for about 4.5 years, I have replaced the every thing at one time or another and about 4 control modules in side the distributor yesterday on the dyno a plug wire failed for no reason about 500 miles on the set I have when over every thing about 5 times making sure every thing was connected correctly even had a shop go over it to make sure I didnt goof up something
also the Pro billet distributor was the reason I had to redo the engine the collar on it was not in the right spot so the cam gear eat away at the dizzy gear ruined the rings and bearings
will not buy another MDS part ever!
stroker87 is offline   Reply With Quote
Old 04-15-2014, 11:29 AM   #2
K10Scottsdale78
K10Scottsdale78's Avatar
Re: MDS SUCKS waist of money!
How long did your wires last? I just installed MSD wires onto my truck last month, ill be so pissed if 75 dollar wires decide to randomly fail..
-1978 K10 Scottsdale LWB
400 SBC 4 spd muncie SM465 ("heavy chevy")
-2002 Toyota Celica GT
5spd (gas saving daily driver)
-1969 Pontiac Firebird (post-college project car)
K10Scottsdale78 is offline   Reply With Quote
Old 04-15-2014, 11:34 AM   #3
stroker87
one set lasted about 1500 miles 2nd about 1000 then I had a crack in a few of them 3nd less then 500 it was the make your own kit wire gave away again
none was touching the headers and the couple that was close has boots on them
I'm done with msd going to try tailor or some thing
Old 04-15-2014, 11:38 AM   #4
imjeff
imjeff's Avatar
Did you contact MSD? Companies don't last long if they turn out expensive crap. They sell a ton of stuff, but I'd be curious what they have to say before trashing them.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-15-2014, 11:44 AM   #5
stroker87
yes I did they say its some thing I done not there product, if I was wrong fine I would understand but the performance shop looked it over too and said it was correctly installed and they see a lot of msd failures too
the last set of wires was sitting in a box under my work bench inside my home for about 4 years and now there trash but funny how my other cars parked out side true the winters have over 30k on wires......
Old 04-15-2014, 11:52 AM   #6
imjeff
imjeff's Avatar
Re: MDS STINKS waist of money!
I usually use Taylor's myself, don't have much use for the pretty wires. I have used their ignition boxes and some other bits and pieces, but plug wires are right up there with religion and politics for some. Good luck!
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 01-22-2016, 11:18 PM   #7
hjewell2
hjewell2's Avatar
I also have had bad luck with MSD items , Bought one of their dizzys and was a piece of junk.
hjewell2 is offline   Reply With Quote
Old 01-23-2016, 11:20 AM   #8
Ta12sec
I had a msd setup and had the same expericence, used to drop coils every 500 miles. I used to keep spares in the glove box and would pull over and change them out. One of the leading reasons all my future toys will be fuel injected.
Ta12sec is offline   Reply With Quote
Old 01-23-2016, 11:50 AM   #9
zeldman
zeldman's Avatar
I have had a MSD set up on my '93 GMC for 16 years now without a single problem. Except when I put a new module in the distributor, It was a Chinese product that failed right after startup.
I used MSD on my race cars. The only problem I had was when I stuffed one into the wall and it sort of destroyed the box as the front half of the car was ripped off. Yeah, I felt that one for a while.
Everything I own has a MSD of some sort on it. If I could get one to work on my lawn mower and airplanes they would be equipped as well.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-24-2016, 12:22 PM   #10
gmachinz
About 80% I'd say of MSD stuff is from China-so draw your own conclusions there. Only their high end digital race stuff (ProMod, Top Fuel stuff) is still US made. For the typical consumer MSD has the philosophy that since they are so huge, they get away with selling turds because as long as people are happy getting a NEW free MSD turd to replace their defective MSD turd, then the MSD wheels can just keep turning and turning. I prefer Mallory Ignition (but now have been bought out....) and Taylor wires. Both to my knowledge are US manufactured a and we used to run Taylor 409 race wires on the sprint cars because MSD wires couldn't handle the extreme vibrations combined with sustained high RPM runs.
gmachinz is offline   Reply With Quote
Old 01-27-2016, 02:55 PM   #11
hoist00
Just like a lot of companies that used to be good but now outsource all there materials and work. Don't post a reply about how good the company is if there product has been in your truck for more than five years cause chances are the old stuff is still good but anything they produce now is crap and they rely on there old reputations to push out newer junk.
hoist00 is offline   Reply With Quote
Old 01-27-2016, 03:08 PM   #12
Wasted Income
Boosted Member
Wasted Income's Avatar
Firecore50 wires are where it's at. Expensive but well worth it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
