Old 04-19-2014, 07:53 PM   #251
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 1971 K20- project just get driveable!!
Thanks guys, appreciate all the positive feedback.
Thinking I need 285/75/16 meats on there. The tires on it are about 10 years old and 1/4 of full tread left
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-19-2014, 08:32 PM   #252
SS Tim
SS Tim's Avatar
Or 255/85/16 tires. What size wheels are you planning?
As an example Toyo suggests 6.5-7.0-8.0 for the 255 and 7.5-8.0-9.0 for the 285 with both tires being right at 33.2-3" in the M55 series.
SS Tim is offline   Reply With Quote
Old 04-20-2014, 12:29 AM   #253
Vintage Windmills
Vintage 4x4s
Hi Tim,
i'm running 7" rims and agree with the guys here that 70 series and up are ok on that rim with a 285 and narrower tire. Going to price out those toyos though.
http://67-72chevytrucks.com/vboard/s...d.php?t=582186
Old 04-20-2014, 01:40 AM   #254
SS Tim
SS Tim's Avatar
Found them looking for C30 tires that would live at maxc. GVW. They are commercial all season tires. The 285s are E rated at 3700lb and the 255s are also E at 3400lb. Expect to pay about $300 a corner IIRC.
Old 06-06-2014, 05:31 PM   #255
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Jud, how's the truck treating you?
Ryan
1969 Chevy milk truck
Old 06-09-2014, 12:41 PM   #256
Vintage Windmills
Vintage 4x4s
hi Ryan, I have been wanting to post an update but too busy parting a couple trucks and making pickup box trailers
A few weeks back I swapped a different rear hatch on the topper and put on an ochre tailgate. new lift cylinders on hatch too.
Havent driven it much at all since it had driveability issues. 1). it pulled hard when braking. That sealed the deal that i might as well rebuild the front axle that I never got around to before. I figured as long as the hubs are coming off, it getting new dust shields, bearings, rotors, calipers, caliper mounting plates, ball joints, tie rods, seals, lugs, everything but gears and bearings on the carrier.
issue 2). is it stumbles alot accelerating. I checked the timing and found the vaccuum advance isnt working. Theres a new distributor sitting here waiting for me to install.
Old 06-09-2014, 08:45 PM   #257
Dieselwrencher
I hate to say it, but right now is a perfect oppurtunity to ditch that gasser and small D44. You have the donor pieces on hand, right?
Ryan
Old 06-09-2014, 08:51 PM   #258
Vintage Windmills
Vintage 4x4s
Yeah, if I was smarter I'd probably just go that route: chevy:
And if those wer'nt big enough hints, the Sm465 trans sticks going into second gear... I've got a getrag/205/gearvendors sitting here with the 12V and D60.......
If the Dana 60 didn't need rotors and seals, or was 4.10, I'd swap it in. Also, I keep thinking the frame on the K20 needs to be beefed up first or I should just find a C30 or longhorn!
Old 06-09-2014, 09:00 PM   #259
Dieselwrencher
Just buy the parts for the D60 and do it once instead of twice. Sounds like the 4 speed is about ready to die too. Keep going, you might talk your self into it.
Ryan
Old 06-09-2014, 09:12 PM   #260
Vintage Windmills
Vintage 4x4s
While on the topic, I did pick up some more "parts" a few weeks ago. '93 with Spun bearing in engine, body has rust, but chassis is solid and this truck was maintained and has overdrive A518 so thinking maybe I will fix and use this as a winter tow rig, then in 5 years when I'm on my second 12v conversion, harvest these parts.
Trying to figure out if I want to swap in the other 12V from the '90 white truck or try to stab in new bearings with the engine still in the truck???
Old 06-09-2014, 09:19 PM   #261
Vintage Windmills
Vintage 4x4s
Already have the parts for the D44, so I will "practice" by rebuilding it
Below is the '90 getrag, 5spd donor, 3.54 D60 totally shot body and chassis is rusty too. I'm running it now with a D60 rear I rigged up for it. Wouldn't mind trading one of my 3.54 Dana 60's for a 4.10 one.
Old 06-10-2014, 03:49 PM   #262
Dieselwrencher
Jud, chances are if it spun a bearing, the crank will need polishied and the rod could need resized. It might be easier to swap engines for now and rebuild this one for your next project.
Ryan
Old 06-11-2014, 12:02 AM   #263
Vintage Windmills
Vintage 4x4s
You think its worth pulling the oil pan in the truck to check it out? Or are the odds of it being good so low, I should just swap engines?
Old 06-11-2014, 03:39 PM   #264
Dieselwrencher
It's been a while since I've worked on a 1st gen engine in a 1st gen. I can't remember if there's room to get the pan off without picking the engine up or not. If you have to pick the engine up to remove the pan, you might as well yank it IMO. You're half way there. And if you have my luck, there will be more issues than a light spun bearing.
Ryan
Old 06-22-2014, 05:54 AM   #265
Cobalt964ruf
Cobalt964ruf's Avatar
Very nice ochre build.
Cobalt964ruf is offline   Reply With Quote
Old 06-29-2014, 12:22 PM   #266
Vintage Windmills
Vintage 4x4s
Overdue for an update. Needed brakes and I figured as long as the hubs are coming off, it getting new dust shields, bearings, rotors, calipers, caliper mounting plates, ball joints, tie rods, seals, lugs, everything but gears and bearings on the carrier since that seems good, fluid was good, and it only spins a fraction of the time anyways. Lots of PART$
Old 06-29-2014, 01:00 PM   #267
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
It's gonna drive like new
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-29-2014, 02:44 PM   #268
ryanroo
ryanroo's Avatar
its a good feeling to get the front back in good order. driving something that is nice and tight in the front makes a big difference in your attitude towards the vehicle.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-29-2014, 03:46 PM   #269
hgs_notes
GEARHEAD
hgs_notes's Avatar
Hard to believe how quick all those new parts add up. I did the front suspension rebuild on my C10 this winter and without the brakes spent a few hundred. And that was after bargain shopping for a while. There won't be much left to overhaul on this truck soon. Great job as always.
hgs_notes is offline   Reply With Quote
Old 06-29-2014, 04:11 PM   #270
Vintage Windmills
Vintage 4x4s
I hope so Dale, really curious to test out the rear brake conversion with proper brakes on all 4 corners!
Ryan, right on, road feel is pretty important to me. I felt a little shimmy in my high mile commuter Honda today and it was pretty unsettling. Made me wonder if the lugnuts were tight!
Mike, yeah, there is no lack of parts here. Suddenly the IFS Chevys don't seem so bad!
With a proper front end, it will be interesting to see how good/bad the stock steering box is. My only real experience with a roadworthy K20 was with an upgraded AGR variable ratio box.
Old 06-30-2014, 07:52 PM   #271
Dieselwrencher
Nice looking pile of parts. It's never ending it seems.
Ryan
Old 08-12-2014, 09:49 AM   #272
Vintage Windmills
Vintage 4x4s
Pics of front end when i was working on it.
working on distributor replacement now. vacuum advance wasnt working at all. Hope that solves the chugging while accelerating.
Old 08-12-2014, 01:33 PM   #273
Vintage Windmills
Vintage 4x4s
Pic for above post plus one of a test fit on 32' trailer. Plenty of room, a 30' would work
Old 08-12-2014, 06:16 PM   #274
Dieselwrencher
Making a trip soon Jud?
Ryan
Old 08-13-2014, 09:30 AM   #275
Vintage Windmills
Vintage 4x4s
Ryan, no trips with it this month unless i get time to part a couple trucks and make time for a scrap run. I was either faced with replacing the axles on the tandem with heavier ones but the price was getting up to 1600 just for axles with brakes and hubs so i thought it may make sense to get another trailer, then i saw this older but well maintained 2 place for about the same price and couldnt pass it up. Now i really need to get that diesel going or do the cam/tune/headers on the lq4 At least the unloaded weight is fairly low on this one, and its pretty low so drag will be less. Feels about the same weight as my tandem empty (3600), maybe a tad lighter.
