Old 05-05-2014, 05:41 PM   #1
1911a1
1911a1's Avatar
temp guage sending unit?
Is there a 3/8 temp gauge sending unit that will work with the factory temp gauge?
The summit racing double hump heads on my engine are set up for 3/8".
According to the summit tech line aftermarket gauge sending units will not work with the factory gauge.
Thanks!
1911a1 is offline   Reply With Quote
Old 05-05-2014, 05:52 PM   #2
Lee H
Lee H's Avatar
Re: temp guage sending unit?
Not that I know of. It's pretty easy to drill the 3/8s hole out and tap 1/2 threads to match the correct sender. You can also put the sender in the intake.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-05-2014, 06:25 PM   #3
FirstOwner69
FirstOwner69's Avatar
See post 15 in this thread. He (brian mac) turns down the originals and rethreads them. I think he charged me something like $20.
http://67-72chevytrucks.com/vboard/s...d.php?t=484537
FirstOwner69 is offline   Reply With Quote
Old 05-05-2014, 08:31 PM   #4
1911a1
1911a1's Avatar
Thanks for the replies!
the Edelbrock intake location for it is right next to the water neck kind of tight, also its a used intake with a steel plug in it that may not come out. The heads are already on the block what about steel shaving getting in the water jacket when you drill and retap? I guess you could try to vacuum them out?
Old 05-05-2014, 08:49 PM   #5
1911a1
1911a1's Avatar
yep, just tried to remove the plug, no dice, heating with a torch might do it but I'm not going to try it.
Old 05-05-2014, 09:06 PM   #6
74baggedbug
Just get a factory temp sensor and have it machined down.. I went thru those headaches a few months back..
74baggedbug is offline   Reply With Quote
