05-27-2014, 01:14 AM | #1 |
Installing body mounts?
I have new body mount bushings to install and im wondering whats exactly i would need to do to install front and rear cab bushings without removing entire cab?
05-27-2014, 01:20 AM | #2 |
Re: Installing body mounts?
Loosen but don't remove 3 of the 4. Jack up one corner at a time and slide out the old mount and replace. Repeat for the others and you are done.
05-27-2014, 02:00 AM | #3 |
Ok seems easy enough! thanks!
05-27-2014, 02:12 AM | #4 |
I loosened all of them first, including the radiator support as there are rubber mounts there as well, then i jacked up one side first using 2 jacks, one on the rad support and the other for the cab using a block to spread the weight load.
Keep an eye on your brake lines and shift linkages ect on the driver side.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
