Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-02-2014, 06:40 PM   #1
KyleSeal
KyleSeal's Avatar
Turn Signal & Headlight Problem
I have a '70 that is having some light issues.
The turn signals don't work completely. You can see the light go in and out but it's a very small difference in light output. The headlights are also unequal, the passenger is a lot brighter and the driver is dim. Same goes for the other lights on the grill.
The side markers light up, but do the same blinking problem.
Would there be a benefit to just replacing all the fuses in the box or is this a problem in the harness by the headlights?
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 07-02-2014, 07:06 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Turn Signal & Headlight Problem
You need to do this....
http://67-72chevytrucks.com/vboard/s....php?p=4200642
LockDoc
Leon
Old 07-02-2014, 07:16 PM   #3
cdowns
cdowns's Avatar
cleaning all the connections helps alot as far as havin the juice flow and causeing the lights to b bright
Old 07-02-2014, 11:59 PM   #4
KyleSeal
KyleSeal's Avatar
Originally Posted by LockDoc View Post
What will that do with respect to the headlights? Just curious. Still learning, first truck.
Toano VA
Old 07-03-2014, 12:00 AM   #5
KyleSeal
KyleSeal's Avatar
We cleaned the connectors to the headlight with dielectric. When we 'wiggle' the connector it goes from bright to dim.
Toano VA
Old 07-03-2014, 12:35 AM   #6
LockDoc
LockDoc's Avatar
Grounds make a difference with everything. The cab and radiator core support sit on rubber bushings so they will not ground correctly without ground straps. That is also why you need a ground strap from the engine to the frame. The engine and transmission mounts are rubber cushions that isolate them from the frame....
If you are talking about dielectric grease it is not a cleaner. If you mean contact cleaner you still have to clean the mating contacts with a small flat file or fine sandpaper to get any corrosion off.
LockDoc
Leon
1970, c10, headlights, lighting, wiring
