Old 07-08-2014, 10:16 AM   #1
ASEASIDER
Need a picture of hatch support mounted on hatch
The body shop is finishing up on my blazer. One thing that I noticed that the hatch supports have a lip on the the outside edge. Is that lip suppose to seat down into the outside edge of the hatch. Right now the outer lip is causing the hatch supports to stand off the hatch slightly (not flush with the hatch). Any pictures would be greatly appreciated
ASEASIDER is offline   Reply With Quote
Old 07-08-2014, 09:23 PM   #2
warbucket
warbucket's Avatar
Re: Need a picture of hatch support mounted on hatch
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
Old 07-08-2014, 09:35 PM   #3
ASEASIDER
Greatly appreciate the pix warbucket! I was just checking out your progress and pictures and noticed the exact same picture. I hope you don't mind if I sent that picture to my body guy. I have a couple of questions you may be able to help me with. On the roof where the hatch hinges go in to wasn't there a grommet or seal of some sort? Also the blazer I have has cut down truck doors, I have found a complete set or two of the brass and stainless steel door stops. My problem is that there are no holes in the door or door pillar above the door catch plate for the door stops. Is there a location measurement somewhere so I know where to mount these.
Thank you again for the pix and keep up the good work! One nice looking rig you got
Old 07-08-2014, 10:05 PM   #4
warbucket
warbucket's Avatar
On the top there is a rubber seal that is held in by a metal retainer, you can almost see it in the first pic above. Also in this one.
I can get some pic of the inner pillar hole location and some measurements, I haven't installed mine yet but the holes in the pillar are original.
Old 07-09-2014, 07:30 AM   #5
ASEASIDER
Sounds good! Thank you!!!
Old 07-11-2014, 09:03 PM   #6
warbucket
warbucket's Avatar
Her ya go.
Old 07-12-2014, 03:59 PM   #7
Senorx
Senorx's Avatar
Originally Posted by warbucket View Post
Your immaculate hardtop makes me wanna cry!
Senorx is offline   Reply With Quote
Old 07-13-2014, 08:26 AM   #8
ASEASIDER
Thank you for the measurement warbucket.
