Old 01-12-2004, 02:08 PM   #1
racedvl
racedvl's Avatar
Question Caprice rear disk question. . . . .
Ok, I can get a entire rear end from a mid to late 90's Caprice from the local bone yard for $150. It has rear disks. I have read that you can use the rear rotors on a 12 bolt, but can the entire Caprice rear disk set up be used on a truck 12 bolt? Will the backing plates bolt to the truck rear end? The Caprice is kinda buried in the dirt so I really can't get any measurments that would be any good to find out. Plus $$$ is real tight right now, so I don't wanna end up with a $150 boat anchor sitting in my garage. Does any one have any input on this situation? Any help would be awesome. Thanks.
racedvl is offline   Reply With Quote
Old 01-12-2004, 05:32 PM   #2
racedvl
racedvl's Avatar
TTT
Old 01-12-2004, 09:15 PM   #3
john
member #16
john's Avatar
There is some caprice info and pics in this thread.
http://67-72chevytrucks.com/vboard/s...ar+disc+brakes
john is offline   Reply With Quote
Old 01-12-2004, 10:24 PM   #4
racedvl
racedvl's Avatar
I have seen that thread. That is how I know that the Caprice rotors will fit. I was wanting to use the Caprice backing plates though, so I can use the Caprice parking brake, and be using all GM parts.
Old 01-12-2004, 11:52 PM   #5
383 Stroker
383 Stroker's Avatar
The Caprice backing plate will not work on a 12 bolt. The axle tube on the Caprice rearend is smaller and the bolt pattern for the backing plate is different.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 01-12-2004, 11:57 PM   #6
383 Stroker
Here is a picture of my rear disc brakes.
Old 01-13-2004, 01:32 AM   #7
racedvl
racedvl's Avatar
383 Stroker, what did you use for brackets? I can get cailpers and rotors at work, so reallythe only thing holding me is a bracket set-up. I do need a parking brake though. Hhhmmmmmmm. . . .
Old 01-13-2004, 01:31 PM   #8
383 Stroker
I made the backing plate out of 3/8" steel.
Old 01-13-2004, 11:46 PM   #9
racedvl
racedvl's Avatar
