08-31-2014, 01:03 PM | #1 |
Part # help.. Hub retaining ring
08-31-2014, 01:10 PM | #2 |
Re: Part # help.. Hub retaining ring
Is that for the rear of a 14 bolt? What's wrong with it?
08-31-2014, 01:13 PM | #3 |
its from a HO52 rear end, floating hub. Ive had some issues with the outer bearing and this was pushed out of the track it sits in when the last bearing ate itself.. id like to replace it to make sure it good to go..
Here is my saga... http://67-72chevytrucks.com/vboard/s...=1#post6823299 |
08-31-2014, 01:16 PM | #4 |
Got it. Same set up as the 14b.
Sure the number is correct, not coming up an anything I have here |
08-31-2014, 01:27 PM | #5 |
thats the issue.. either am I.. it was a number passed on to me.. but i can't seem to find it..
Hoping someone else has purchased one..maybe a Dorman part number or something... |
08-31-2014, 01:41 PM | #6 |
My Dorman book is every bit of 2'' thick and does not have a listing for that
08-31-2014, 01:49 PM | #7 |
I've seen it called a "Hub Retaining Ring" and this web page
http://www.gmpartswiki.com/getpage?pageid=26789 has it as a "ring spacer retainer" with the same part # i have listed above.. |
09-01-2014, 06:56 PM | #8 |
Bump..
09-02-2014, 05:32 PM | #9 |
The part #'s for flat washers, nuts, and retaining washers are the same for the H052, Dana 60, and the Corp. 14 bolt are the same. Maybe they are for the bearing retainer. I would check the groove in the hub also. It always seems those are tricky to look up. I looked on RockAuto, that's were I got my retaining washers for my 14 bolt, I had to punch the part number into search.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
09-02-2014, 07:09 PM | #10 | |
