11-04-2014, 01:31 AM | #1 |
What's needed to convert to a powersteering setup?
I want to convert to a powersteering from manual now...what is needed to accomplish that?
I found an ad for for a powersteering box with the pitman arm and pulleys. Is there anything else I need to go with it? |
11-04-2014, 01:45 AM | #2 |
Re: What's needed to convert to a powersteering setup?
If that is a kit, that should be all you need aside from a belt and fluid, some grade 8 7/16'' bolts to put the box on the frame and a few other bolts. Kit should have the matching crankshaft pulley. What year we working on?
11-04-2014, 01:49 AM | #3 | |
http://sfbay.craigslist.org/eby/pts/4742970483.html What do you guys think? |
11-04-2014, 01:51 AM | #4 |
Moderator
Brackets, pump, hoses, power steering box, belt, pump/crankshaft pulleys.
Big block, small block, inline 6, V6, short or long water pump if a V8? There are a LOT of variables to consider.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-04-2014, 01:53 AM | #5 |
11-04-2014, 12:47 PM | #6 |
go to the junkyard.....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
