Old 11-29-2014, 05:29 PM   #1
72Thunder
Positive Ground Battery Connection
Hi all,
I have just started the tear down process of my '72 C10 and when it came time to take off my passenger side fender I noticed my positive battery wire had been grounded to which looks like a factory piece on the fender. We thought it was alright cause the truck could start and drive just fine but as soon as we figured we didn't need it we took it off it but it never powered up. So we found a new "ground" for it (rad support), it started to spark and eventually caught on fire. i am confused by this as after everything cleared up we put it back on the fender and everything started up all fine and dandy. Is there something I'm missing?
72Thunder is offline   Reply With Quote
Old 11-29-2014, 05:33 PM   #2
72Thunder
Re: Positive Ground Battery Connection
Here's another picture
Old 11-29-2014, 05:43 PM   #3
Jim53066
Jim53066's Avatar
Yes, that is not a ground, that is a junction block for the hot wire. The stud rests in the plastic mount and never touches the fender.
Jim
Jim53066 is offline   Reply With Quote
Old 11-29-2014, 06:05 PM   #4
REEDS 72
REEDS 72's Avatar
NOT A GROUND/take pics and put back together as you found it.
REEDS 72 is offline   Reply With Quote
Old 11-29-2014, 06:30 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Also, the black wire beside it with the integrated fuse holder (4amp) needs to be hooked back up to the junction block or your amp meter won't work. There should be another fuse holder just like it on the drivers side of the core support. Make sure the fuses are good and the contacts are clean....
LockDoc
Leon
Old 11-29-2014, 09:14 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Sounds like you fried your old Fusable Link. That needs to be replaced with another similar length of same-gage fusable link wire.
My Dad had a '59 Jaguar that really did have a Positive 'Earth' System. Lucas Electrics. Now I know why the Brits drink warm beer... [Their fridge is broken].
'68OrangeSunshine is online now   Reply With Quote
Old 11-29-2014, 10:54 PM   #7
kcsa75
kcsa75's Avatar
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-30-2014, 01:55 AM   #8
72Thunder
Hahaha that's funny. Thanks all for the replies and information. Checked it out even further and got everything working as it should the correct way without any fires this time! Definitely appreciate the input.
Thanks,
Darcy
Old 07-04-2021, 05:36 PM   #9
54blackhornet
54blackhornet's Avatar
Why did GM run the positive wire through that black plastic block on the fender ? What is that connection for ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-04-2021, 06:55 PM   #10
HO455
HO455's Avatar
I believe it's primary reason is for the fuseable link. Which is between the battery clamp and the insulated post. If the fuseable link blows it can be replaced without cutting into the harness. I'm pretty sure 67 was the first year for fuseable links and by 73 GM had decided there was no need for an easily replaced fuseable link so it was integrated into the harness to save money and confound generations of shade tree mechanics.
Its secondary use is for one leg of the amp guage wiring. It is connected at the insulated post. Having that connected to the insulated post keeps the fuse and fuse holder away from the battery post and its corrosive fumes.
RIP Bob Parks.
Old 07-04-2021, 07:19 PM   #11
slikside
slikside's Avatar
One reason is that is where the alternator joins with the battery. Think of it as that wire gets the juice to charge the battery from that post, which is supplied by the alternator. My alternator wiring runs to the radiator support, along the top inside edge and exits right above the battery. There is a 10 or 12ga red wire that terminates on that block. Then a smaller section joins the block with the + terminal of the battery.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 07-04-2021, 09:16 PM   #12
FirstOwner69
FirstOwner69's Avatar
It also served as the attachment point for the hot wire included with the optional camper harness. The wire was then routed along the top of the radiator support to the left inner fender. The wire then joined the other camper harness wires at the firewall. They were then routed rearward together.
It's the 10 or 12 gauge red wire in the pictures.
I don't know how this varied when the dual battery option was also ordered.
Jim
FirstOwner69 is offline   Reply With Quote
Old 07-05-2021, 10:38 AM   #13
54blackhornet
Thanks for the explanation. Still don’t understand why they didn’t just insert a inline fuse instead of the fuseable link ?
71 C-20
07 Magnum RT AWD
Old 07-05-2021, 11:35 AM   #14
Grumpy old man
Grumpy old man's Avatar
Safety First Fusible link
You are most likely familiar with how a fuse works in an automobile, but here’s a quick reminder. A fuse serves as a link in your vehicle’s electrical system that can be broken under certain circumstances in order to protect various components and systems from damage. Typically, a fuse burns out when a circuit attempts to transmit too much current, severing the connection before the electrical charge can have any ill effects.
A fusible link acts much like a fuse, only it’s designed to handle a different type of potentially hazardous scenario. These links are actually strands of wire wrapped in a fireproof covering, and are thinner than the wiring harnesses they’re connected to. They are placed in-line between delicate harnesses and large sources of electrical current in your car—between the battery and alternator, for example. These links must transmit high-current electricity, but also protect the rest of the electrical system from dangerous spikes that could cause a fire. If there’s a surge, the link actually melts, as its resistance to heat is lower than that of the circuits it’s protecting. This cuts off power while protecting the engine bay from a conflagration, thanks to its fireproof wrapping.
When replacing a fusible link buy 2 and leave one in your glove box .
Never replace a fusible link with standard wire unless you like fires .
Old 07-05-2021, 03:02 PM   #15
'68OrangeSunshine
Hi Jim, I looked it up on the Google box. In the stock setting, yes, that red wire does cross to left and connect with the Pos terminal of the B battery. If there's an Isolater unit, a feed from A batt goes to one ternimal on the Iso and B batt to another, then a Red wire output to the Alternator, and connections to appropriate grounds, too.
Old 07-05-2021, 03:09 PM   #16
HO455
HO455's Avatar
The fuseable link is a like a slow blowing fuse. In other words it will tolerate an over current condition much longer (relatively speaking) than a fuse will. Thus allowing high amperage current draw when starting the engine yet still protecting the vehicle from a direct short to ground.
RIP Bob Parks.
Old 07-07-2021, 01:18 PM   #17
Big Kev-O
Big Kev-O's Avatar
Originally Posted by 72Thunder View Post
Hi all,
Yes, you are missing a basic understanding of domestic 12v automotive wiring. I am not trying to be a jerk & this looks like this may be your first time dealing with automotive wiring so I will explain some basics to keep you from learning the hard way. Most American cars are designed with a NEGATIVE ground which means the entire chassis and every piece of metal bolted to it are connected to the negative terminal. Under no circumstance should you ever place a positive wire onto your chassis or anything metal. This will cause a short that will spark, melt wire and possibly start a fire if the circuit is not protected by a fuse. Most of the electrical components in your truck do not have negative wire that runs back to the battery because you can complete the circuit by grounding the negative wire to the chassis/body. For example your lights & radio have a positive wire coming from the fuse block through a switch and the negative wire is grounded to the chassis/cab. This is why you only see one negative cable leaving the battery.
Big Kev-O is offline   Reply With Quote
Old 07-07-2021, 01:40 PM   #18
palallin
Be careful--not ALL American cars had Neg ground. Go back to the '50s and earlier, and you will find Pos ground. Likewise, most Ag equipment prior to about 1960 had Pos ground.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 07-07-2021, 05:18 PM   #19
jabborabbo
jabborabbo's Avatar
I have several old Triumph motorcycles…the Brits were correct….
Technically, the current in a circuit travels from the negative terminal to the positive terminal (since that’s the path of the traveling electrons which are negative).
You can blame or credit Ben Franklin (who knew nothing about electrons, protons, etc.) for the Yankee definition of current flow from positive to negative.
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is online now   Reply With Quote
Old 07-07-2021, 06:16 PM   #20
54blackhornet
My 1967 MGB G/T was originally positive ground. Converted it to negative. Tossed the original positive ground radio for a blanking plate, and had to mod the tachometer. Still running the original generator to...
71 C-20
07 Magnum RT AWD
Old 07-07-2021, 06:35 PM   #21
'68OrangeSunshine
In his defence, Mr Franklin was making discoveries about a previously unknown force. One that had traditionally been attributed to the Divine. Chances of perceiving polarity were 50-50, especially at the end of a kite wire.
I worked in the Electrics shop on the early AV8A Harriers. Hawker-Siddeley and British Aerospace subcontracted with Lucas Electric for many system components. The Lucas Refrigeration gag was well known. As was the ''Prince of Darkness''. The aircraft had 2] 28 volt DC busbars w/ Negative ''Earth.''
Old 07-07-2021, 08:31 PM   #22
54blackhornet
68 ! You are spot on ! Could not have summed it any more eloquently...
71 C-20
07 Magnum RT AWD
Old 07-07-2021, 09:17 PM   #23
Killer Bee
Killer Bee's Avatar
1964 model E - positive ground
starter cable was a little short but got me by to get the old girl rolling again..
can't see the battery top but note the color of the clamps on charger leads
Old 07-07-2021, 09:38 PM   #24
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Positive ground. In the Physics Department, we used "i" to define the current. In the Engineering Department, they used "j". Tastes Great, Less filing! When one gets to a junction and gets a negative current answer when applying Kirchoffs's rules, it simple means that the current is flowing in the other direction. That seemed to blow people's minds. I was in an engineering class (working on a master's degree, but dropped out because of my workload at my job) back in the '80s where the instructor drew an arbitrary curve and defined the current flow as "to the right" Then he said that -i was current flow in the other direction. Some of the student's heads pretty much exploded, at that point. By the time people took that class, they should have at least had vector calculus and differential equations, and gotten the significance of the sign change without a hiccup.
~Steven
Simi Valley, CA
Old 07-07-2021, 10:16 PM   #25
body bolt
My 1967 MGB G/T was origi=nally positive ground. Converted it to negative. Tossed the original positive ground radio for a blanking plate, and had to mod the tachometer. Still running the original generator to...
Flash the field. Isn't that one of the first things one did to an LBC?
body bolt is offline   Reply With Quote
1972 c-10 pick up, battery, fender, ignition, wiring
