Old 12-01-2014, 04:53 PM   #201
Iceburgh
Iceburgh's Avatar
Re: 53 Surburban "Family Truckster"
Looking forward to updates as well.
Marc or any of you other guys building Burbs.
If you need anything let me know.I have some ( not much) original items sitting around.
They will go on EBAY soon. If you need something I can check if I have it.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 12-01-2014, 11:22 PM   #202
youngrodder
youngrodder's Avatar
Iceburgh-
I'm pretty well set with original items. I'm still looking for a rear splash pan but I it not a must have at this point. I know you sold yours a while back.
Very cool gesture to give us first dips though.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-02-2014, 11:24 AM   #203
reaper71
reaper71's Avatar
Looking good Marc...if this comes out anything like your truck it will be badass...(must be a Michigan thing LOL Born and raised there myself!) Your boys working on the burb with you is killer..reminds me of me and Dad (oldman3) years ago and still going...
Mark...
reaper71 is offline   Reply With Quote
Old 12-02-2014, 11:38 AM   #204
youngrodder
Mark...
Thanks Mark..
The plans for the Burb will be quite a bit different than the truck. The finished product wont be as polished as the truck but It will get used more often with the whole family. More of an ultra low family cruiser.
Good to hear you have wrenching in your family as well. We have to keep this hobby going..
Marc
Old 12-07-2014, 09:29 PM   #205
youngrodder
Well I got some garage time this weekend. First over the past month or so I worked on adding a 80K BTU natural gas heater. This should make wrenching during the winter months more enjoyable. I included a picture of the diver side quarter panel that I patched using a lower driver side door patch. A picture of my seat riser. I had to restore the bottom edge and weld up some small holes. Then it was sand blasted and put in primer.
The last two pictures are just to prove that I still have my Suburban..ha ha ha
I heard that Porterbuilt is getting pretty close on the AD kits. The body is now ready to come off the frame. I'm concerned how I'm going to separate the two. I don't have a hoist. Anyone out there that can share a method that worked good for you would be appreciated. I'm guessing just get a bunch of strong friends to help lift it off.
Marc
Old 12-07-2014, 09:32 PM   #206
youngrodder
I also spent some time making these stands. They work great for working under your truck an allowing it to remain at ride height.
Marc
Old 12-08-2014, 12:19 AM   #207
99 to Life
99 to Life's Avatar
congrats on the heater and garage time. coming along nicely. the blocks are def a great thing to have, like and idiot I don't have mine made yet.
as for the burb body. I'd nail two long 2x4's together to make a nice sturdy plank. Lift the cab off the frame enough to slide the planks under so they stick out past the Running board brackets. You'd have to do one plank up front, maybe not back. Jack up cab so its off frame put jack stands under the planks, slide frame out. Kinda hard to explain but you can't just jack the cab up and brace it cause the RB brackets would hit the jacks, so you just gotta use the plank to get the jacks out past the RB brackets.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-08-2014, 12:21 AM   #208
oldman3
oldman3's Avatar
Marc, shop looks great, heater should keep you warm. Burb looks good...Jim
oldman3 is offline   Reply With Quote
Old 12-08-2014, 10:55 AM   #209
reaper71
reaper71's Avatar
Looking good Marc!!!
Just my 2 cents worth but this is something I built for keeping vehicles at ride height....Using 2 x 2 x 1/8" tubing welding a nut to the bottom and using a bolt and washers at the bottom as well. These can be tacked to the frame/front end etc. Then using the head of the bolt can be adjusted as needed. (washer welded to bolt head) Then with the tubes tacked in place you are able to move the chassis anywhere you like and still maintain the same measurements..
Mark...
Old 12-08-2014, 11:14 AM   #210
reaper71
reaper71's Avatar
another pic of the stand.
Old 12-09-2014, 04:38 PM   #211
Advanced Design
Advanced Design's Avatar
Great gesture on the parts Iceburgh.
Great idea Reaper, appreciate the share.
Looking good Marc! A warm shop is a wonderful thing. Looking forward to updates!
Advanced Design is offline   Reply With Quote
Old 12-09-2014, 08:13 PM   #212
GEARBOXGARAGE
Keep up the progress Marc! Can't wait to see this thing on the road.
GEARBOXGARAGE is offline   Reply With Quote
Old 12-09-2014, 11:05 PM   #213
youngrodder
Thanks Mike
I plan on separating the frame from the body within the next two weeks. I told Paul to eat his Wheaties when we get ready for the heavy lifting.
Marc
Old 12-14-2014, 11:13 PM   #214
youngrodder
Spent some time Sunday and build a body cart. I will support the body with 4x 4's and cement blocks. Then the plan is to drop out the frame and slid in the cart to support the body.
The weather was in the 50's today which is very out of the norm for Michigan in the middle of December.....so I decided to take the 48 for a drive.
Marc
Old 12-14-2014, 11:54 PM   #215
wood1
Great picture of the pickup, looks mean!! Suburban is coming along nice
wood1 is offline   Reply With Quote
Old 12-15-2014, 12:27 AM   #216
oldman3
oldman3's Avatar
Cart should work out great, truck looks super as always...Jim
Old 12-17-2014, 09:16 PM   #217
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
here is what i did to get the body off by myself. i just kept jacking it up a few inches at a time till i could run some 4x4 out each side past the frame.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 12-17-2014, 10:49 PM   #218
Iceburgh
Iceburgh's Avatar
a buddy with a lift always works out great
drop it on your cart in about 30 minutes or less
1953 suburban build
Old 12-17-2014, 11:17 PM   #219
youngrodder
Thanks Chizzler. I have a similar plan. I have some cement blocks and a couple of 4 x 4's to get the body high enough to slide the cart under. I really liked the idea of a cart with wheels so that I can move it around. Tomorrow night is the night. I have the jack stands on the ground and a couple buddy's are going to lend a hand. I will take some pics.
QUOTE=CHIZZLER;6961679]here is what i did to get the body off by myself. i just kept jacking it up a few inches at a time till i could run some 4x4 out each side past the frame.[/QUOTE]
Thats' cheating....I could have gone without seeing that pic...ha ha..
Marc
Old 12-18-2014, 12:13 AM   #220
CHIZZLER
CHIZZLER's Avatar
should be a good time. good luck
61-crew cab D-max
Old 12-18-2014, 08:47 AM   #221
Advanced Design
Have fun Marc! Good looking cart you have.
Old 12-18-2014, 11:35 AM   #222
reaper71
reaper71's Avatar
Don't forget your Beer Muscles!!!
Old 12-18-2014, 11:55 AM   #223
youngrodder
Thanks AD looking forward to this step.
Thanks Chizzler, I will take pictures of the divorce.
Reaper....Check!! I told my buds it should only take a bout 30 minutes and a case of beer to complete. I spent some time last night staging things to make it easier tonight.
Marc
Old 12-18-2014, 08:24 PM   #224
reaper71
reaper71's Avatar
Good Times,Good friends and badass projects...
can't go wrong...
Old 12-18-2014, 11:49 PM   #225
youngrodder
Well after 61 years a divorce was inevitable. Good thing for us it wasn't and ugly one. It went really smooth. After screwing around with jacks for 30 minutes we decided to just lift the body off. This went great. We took our time and I had 4 friends over to help with the drinking oh I mean lifting.
Marc
